Originally posted by jgredline I did end up buying a second K-7 and after a day or so of shooting with it, the noise was the same as my original K-7, So I was able to return it. I have conceded that the K-7 atleast for me when shooting Jpegs is to be held at between ISO100 and 640. I did shoot some RAW images and it does clean up to IS01600 but it is not as good as the K20D. So When I know I am going to be using ISO's higher than 640, I grab the K20D. Infact, I have the ISO set to auto 500-2500 in my K20D's and am quite comfortable with that. I am thinking of the K-X now, but the lack of a second wheel and LCD display are a real turn off to me.
For me the real killer is that I don't like to spend a whole lot of time PP pictures so I shoot Jpegs.
Javier, have you tried using NR set to high and to make it start above ISO 400?
I did some testing and it looks quite good on my K-7 for OOC Jpegs.
What about the differences in noise for FW 1.01 and FW 1.02? i have tested it extensively and there is no measurable difference on my K-7.
For what it's worth, i use a K200D when i need better high ISO performance. Its 10Mpix sensor yields cleaner results (which is to be expected with bigger pixels)
Best regards,
Jan Rinze.
