Go to Strobist to learn everything you want about flash photography...
Took me two months to read everything, but man that was worth every second of it...
To answer your question more directly : Bounce!!!
- Direct the flash toward a white surface (ceiling, wall, anything!)
- up your iso to a level you're comfortable with (don't go all the way to 100, or you'll kill all the ambient light!)... 400 iso should be good with a properly exposed flash... (and this will have the added benefits of lower battery drain AND faster recycling times!)
- lower your shutter speed as much as you can...
- forget on-board flash (except if you can use it as a commander for wireless flash)
