10-24-2009, 12:01 PM   #1
K20D flash sync socket problems
Has anyone else experienced problems using the X-flash sync socket on the K20D? I have an external flash unit and hooked it up via the sync socket. It works fine - for one shot. Then it won't fire again until I press the reset/test button on the flash unit. Is there some control within the camera that I have to adjust to successfully use an external flash? I tried the new flash with my old Pentax MX and it works flawlessly (grrr!).
Any help would be much appreciated.
Dan Keeler
10-24-2009, 01:52 PM   #2
Wheatfield's Avatar
Sometimes the polarity of the wire is wrong. Try reversing the wire if you can do it easily.
10-24-2009, 04:19 PM   #3
Thanks for the suggestion - I'd be anxious to do that, though, especially as the flash works the first time.
camera, dslr, flash, flash sync socket, k20d, photography, socket, sync, unit
Outrageously expensive X-Sync socket caps... any other source? Timichango Pentax DSLR Discussion 9 07-21-2010 03:30 PM
out of sync flash k20d af540 LeeHolliday Photographic Technique 23 01-16-2010 12:47 PM
Test: K20D PC sync and older flash Matjazz Pentax DSLR Discussion 8 08-15-2009 02:00 AM
PC sync socket on K20D Anya Troubleshooting and Beginner Help 6 05-15-2009 08:28 PM
K20d Slow Sync Flash jjeling Pentax DSLR Discussion 2 03-22-2009 08:44 PM
All times are GMT -7. The time now is 03:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
