Originally posted by retroflex Does anyone know if the K-x can use CR-V3 batteries?
The K-x manual doesn't say anything about rechargable CR-V3's, but I'd say probably yes, if the output is electrically compatible.
Physically, the profile of the battery compartment is not too snug but there is a slight ridge between each AA pair. So I guess the issue will also depend on the profile of your batteries.
Worth noting: I think the dimensions at least of the battery compartment in the Km/K2000 are identical to the K-x. If they worked on/ fitted into the Km/K2000, they should work on the K-x. It might be worth searching around to see if any Km/K2000 users have reported success using RCR-V3's.
Do RCR-V3's work any better than for example NimH's like the 2000mAh eneloops?
