10-26-2009, 06:20 PM   #1
khardur's Avatar
K200D survives 4 foot fall
Well I'm generally very careful with my equipment. Barely any of it shows any wear, except maybe where the quick-release mount plate screws into the bottom of my camera.
Anyway, I had a holster bag/belt with me the other day, but I had it on the table because I was doing other work. Well I took the camera out (k200d) to take a few quick snapshots then put it back and didn't attach the top. You can see where this is going...
Well when I picked up the bag 5 minutes later I forgot I didn't close the top, and out came camera from about 4 feet up and bounced on the carpet. I guess you could call it carpet, very thin carpet over a concrete floor, but still provided a little bit more bounce than bare concrete alone.
So naturally I turn it on - nothing. I turn it off, turn it on, and the dust reduction thingy goes. Okay... the rear LCD comes on, but nothing else. Ho hum... I'm a little panicked but get in the car and go home. Get home, test it out once more - everything works, just the top LCD and inner viewfinder info doesn't work. I take out the batteries and let it sit for half an hour. Put batts back in and turn it back on - bingo, everything is back to normal.
Woo hoooo! Luck was with me yesterday! Let's hope that doesn't happen again anytime soon...!
10-26-2009, 06:41 PM   #2
Ash
Community Manager
Ash's Avatar
Looks like a close call for you Dan.
Hope it stays functioning well for you...
10-26-2009, 07:27 PM   #3
roentarre's Avatar
Sorry to hear about this Dan.
I had my camera thrown onto the floor so many times to prove that camera gears are not my babies and that I am not obsessed with these gear.
It worked effectively to convince my folks that these are just camera gear.
10-27-2009, 01:43 PM   #4
khardur's Avatar
thanks Ash.
James, yeah while I don't baby my stuff, I generally haven't tossed it on the floor intentionally either.
I just can't afford to replace it, that's all.
10-27-2009, 02:03 PM   #5
I have dropped my K10 two or three times on to concrete floors. The big thing that it changed was that suddenly the auto focus was off -- consistently back focusing. Fortunately, it was fixable with the firmware hack that is out there. Still, accidents happen...
10-28-2009, 12:30 PM   #6
reeftool's Avatar
My Spotmatic was in a backpack that took a fall off a cliff. It survived that one and also 2 motorcycle crashes.
10-28-2009, 08:22 PM   #7
res3567's Avatar
Happened to my K10D on a tile floor which resulted in a cracked viefinder. Everything else ok.
Woo Hoo for you! I am so glad for you!
10-28-2009, 10:49 PM   #8
iceemn360's Avatar
I dropped my k20d off of a good 4 foot bar . It had the da 16-50, grip and 540 flash on it. I forgot I had the flash tethered to my TR battery back as I stepped away from the counter. It landed on a very similar carpet/cement flooring as you had. ironically the tethering probably helped a bit by adding tension before it hit the ground. none the less it was a darn heavy set up to hit the floor. no ill effects.
camera, carpet, dslr, home, k200d, lcd, photography
Camera survives 6 month ocean trip to Fla. xs400 General Talk 6 06-16-2010 05:39 PM
Nikon digital camera survives underwater ocean trip tomwil Non-Pentax Cameras: Canon, Nikon, etc. 1 06-14-2010 01:52 PM
Abstract My Right Foot johnmflores Photo Critique 3 05-31-2010 04:27 AM
K7 survives ocean submersion! stormcloud Pentax DSLR Discussion 1 11-14-2009 08:15 AM
my right foot. dcmsox2004 Post Your Photos! 10 08-16-2009 04:57 PM
All times are GMT -7. The time now is 11:25 AM. | See also: NikonForums.com, part of our network of photo forums!
