10-31-2009, 10:52 AM   #46
I'm on my 3rd set of four. First was Eneloop, then Varta, and now back to Eneloop.
The first 2 sets got me around 1000 photos. I think i can get more, but the batt indicator was red, and I was shooting a wedding for fun as a guest, so i changed earlier.
I use lifeview to focus quite a bit, and tried some Adhoc video as well.
My cam battery setting is set to NiMh.
Nice little cam. All my Nikon friends are amazed by the high iso shot at 3200 and 6400. I can say the photos from D90 ISO1600 can't even get close to Kx at the 3200 setting.
10-31-2009, 11:06 AM   #47
QuoteOriginally posted by mcjm78 Quote
Awesome. I found the camera also killed off my D90 envy. You should start a K-x thread and post a few samples. Weddings can be very challenging subjects.
10-31-2009, 01:27 PM   #48
Thought I'd chime in just to say how excellently my K-x works with my Ni-MH Eneloop batteries. At least 600 shots with regular live view and video recording usage. I have a very high-quality LaCrosse charger, though. That is probably where the problem lies for people with dying batteries.
10-31-2009, 02:03 PM   #49
Just cross-linking for info:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/78291-you-can-read...-exiftool.html
11-01-2009, 09:10 PM   #50
Eruditass's Avatar
Thought I would give this a bump. Please post or PM me with portions of serial numbers and your location, including those who don't have problems so we can see if its a batch or not.
11-01-2009, 09:41 PM   #51
K-x Battery Issue
I'm having issues with my K-x as well. You can see the carnage over at dpforums.
K-x Battery Experience: Pentax SLR Talk Forum: Digital Photography Review
All sorts of battery brands tested including Eneloops and ReCyko+.
Camera was purchased in Toronto, S/N: 34340XXXXX
/kevs
11-01-2009, 10:58 PM   #52
rjm
There seems to be a lot of FUD swirling around.
The battery life with K-x with 1900 mAh AA is 620 shots (420 cipa standard). Video and live view will drain the cells much, much faster.
Still, some people can't get the camera to take more than a couple of shots before shutting down, clearly a big problem.
It seems you have to tell the camera what batteries you are using (NiMH or Lithium) in the menu setup somewhere (I haven't got mine yet so I don't have the manual). The default will be Lithium since that is what the camera ships with.
My worry is people are taking out the lithiums that came with the camera and sticking in NiMH and not setting the camera for the correct battery time. Forgetting to do so will of course generate the kinds of battery depletion/shut down errors some people seem to be experiencing.
It could be a bad batch of cameras, but I would like to positively rule out user error (RTFM!) before making this conclusion.
11-01-2009, 11:05 PM   #53
ogl
ogl's Avatar
As I said before. AA is a big mistake. It's time for Pentax to move to small and compact LiOn in low-end cameras.
11-02-2009, 12:26 AM   #54
After full charging Panasonic Ni-MH, my K-x took some shots without problem - green indicator. I took batteries out and then again put them on, waiting for 30s to turn on. I'm very surprised to see the red indicator. I did many times to take out/on batteries but still had problem of red indicator. This set of Ni-MH was taken 80 shots yesterday. Testing these batteries on Pentax Flash AF200 was OK.
My K-x S/N: 34388XXXXXXXX, was purchased in HCMC, Vietnam
Body made in Philippines
11-02-2009, 02:17 AM   #55
Pentax should just probably say to people: 'in the K-x, alkalines and disposable lithiums work no problem, no matter the brand'.
'But NiMh's have too much variation in capacity, current, voltage, quality, whatever, so we recommend only two brands be used - eg eneloop 2000mAh's (charged with the Sanyo eneloop charger) and something else. We've tested them and they are compatible with the K-x.'
Kind of like they do with SD cards: 'Compatibility with the K-7 has been tested with memory cards from the following manufacturers: Panasonic, Toshiba, Sandisk'.
http://support.pentaximaging.com/documents/384
11-02-2009, 08:03 AM   #56
Eruditass's Avatar
QuoteOriginally posted by ogl Quote
There are many reports of people using lots of high drain functions fine with NiMH, then there are those that are having problems with the same brand, eneloop.
11-02-2009, 03:06 PM   #57
FYI.
For K-x owners trying to understand AA battery issues/problems, the following K200D discussion is one of a number of very illuminating previous discussions on similar issues in this forum:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/45346-k200d-batter...r-problem.html
11-02-2009, 03:50 PM   #58
raider's Avatar
Would rechargeable CR-V3 batteries help with the battery issue? If so, why don't we just use them?
I hope the K-x I get for wifey doesn't have this probs.
11-02-2009, 04:04 PM   #59
QuoteOriginally posted by raider Quote
There's been a lot of previous discussion around rechargeable CRV's too. Short answer is that they don't fit and also they have other problems. Pentax also doesn't like them.
Ricehigh has had some rechargeable CR-V3 fun here with his K-m:
RiceHigh's Pentax Blog: K-m Battery Issue, Solution and Timing Measurbations
Stick with the Energizer Lithiums (or cheaper equivalents like Arlec lithiums from Bunnings which work great too) and only use eneloops for your NiMh's (with an original Sanyo eneloop charger) and I forecast you will have few battery problems.
11-02-2009, 04:05 PM   #60
Eruditass's Avatar
I received mine today. Been playing with it for a couple hours with duracell pre-charged white-top (duraloops) - Live View, Video, etc. Full green bar the whole time.
I'm thinkin bad batch, (un)fortunately. I hope Pentax will do justice to what seems like improper quality control.
australia, batteries, battery, california, camera, canada, dslr, k-x, nimh, photography, post
Batteries: AA NiMh tech v Block LiIon Hypocorism General Talk 15 11-06-2010 10:33 AM
For Sale - Sold: MAHA 8-Battery 1-Hour Charger + 8 Powerex NiMH batteries (MAHA MH-C801D) (Worl pbo Sold Items 1 04-04-2010 10:41 PM
TR III Battery Pack & NIMH batteries? HawaiianOnline Pentax Camera and Field Accessories 4 03-26-2010 11:21 AM
Will a Vivitar 285 work with NIMH batteries? Big Dave Pentax Camera and Field Accessories 3 04-07-2008 03:56 PM
TR Power Pack III Batteries -- NiMH ??? snostorm Pentax DSLR Discussion 4 10-21-2007 09:03 PM
All times are GMT -7. The time now is 10:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
