Originally posted by OutOfFocus The following graphic shows the voltages on "depleted" batteries that can no longer turn on my K-x in Auto battery mode.
It appears the non-LSD batteries are held to a different and much higher standard.
N.B. The Imedions delivered 2600 shots before exhaustion. That's less than 1 mAh per shot.
hmmm... may be I am missing something.
Your graphs seem to show that the non-LSD batteries are doing much better?
But I think the point may have been missed -
these were batteries which were deemed depleted by the Kx - ie: would no longer turn the Kx On.
This means the graphs are an indication of how much charge is still left in the batteries.
So unless I've misunderstood things - the lower the measurement the "better" the battery.
ie: the battery that shows the least remaining capacity is the battery that the Kx managed to utilize the most of the existing capacity.
So let's take the two eneloops that you could not measure - this literally means the Kx managed to drain/use the full capacity of those 2 eneloops - so that there was no measurable remaining capacity.
In my view the eneloops performed the "best" as the Kx was able to utilize almost all of their capacity.
The "worst" would be the non-LSD since they still show a lot of capacity - meaning that the Kx only managed to use part of their capacity - to have so much remaining.
Yes, I do see the eneloops performing "better" than the Imedions - since the Imedions has more remaining capacity than the eneloops - although as you point out with that sort of shot count - almost anyone would be pleased with them.
