Hello, and thanks for your quick reply.. Righty, when it fell i had the standard 18-55 lens, there was no damage i could see to lens or camera, and no visible damage to the contacts. Also tried my Tamron 70-300 same with that.. and it was on the A postion.. and the same for my manual 50mm lens... On another note.. when you put on the manual lens as im sure you know it asks you what lengh the lens is.. Well when i put the 50mm on now.. it does not even ask me that.. Would the contact points def be damaged then??
Marc, your a genius.. I took the actually ring off and cleaned it.. and went over the contacts with a screwdriver.. put it all back together.. and hey presto she is working agian.. You just saved my weekend mate.. Thanks loads.. id have never thought about doing that if you hadnt said
