10-31-2009, 04:05 PM   #1
K100D Super loses exposure settings between power on/off
I shoot mostly manual when it comes to flash photography, and have to set in my Tv and Av settings. I have noticed sometimes that between powering on of the camera, the settings are lost. E.g. I recently dialed in 1/60 and f/5.6 and shot a few pics, powered off the camera. When the power came back on, the Tv was at 1/15 and the Av at f/2.8.
Not sure how this is happening, and my first hunch was that I was accidentally pressing the AE-L button (coming from K10D, I am still getting adjusted to K100D). I am also thinking it could be bad batteries, although I recharged them a day before.
Anyone has had this same issue happen to them?
Thanks!
10-31-2009, 06:03 PM   #2
alohadave's Avatar
It happens to me from time to time when I open the battery door. I just keep an eye out for it. It doesn't happen often enough for me to consider it a big problem.
10-31-2009, 07:16 PM   #3
Its happened to me between battery changes. I think the exposure settings may be one of those which the camera "forgets" if the battery is removed for too long.
Just the normal steps in removing the flat batteries, putting in a freshly recharged set should be fine.
10-31-2009, 10:11 PM   #4
You may need to check the menu for which setting the camera remembers. My K200D has a setting that lists what the camera will keep, your camera may have the same thing.
Rick
av, camera, dslr, exposure settings, k100d, photography, power, settings, tv
HDR: Does the exposure settings in the K7 make much of a difference compared to K20D? Lulerfly Pentax DSLR Discussion 1 11-07-2010 09:25 AM
Rookie question about exposure settings t0mpa Pentax Film SLR Discussion 8 10-23-2010 10:02 AM
K-X maunual settings change after every exposure WTF!!!! Shizz Pentax DSLR Discussion 19 04-01-2010 06:00 PM
K100D loses date on power off - help! melbelv Pentax DSLR Discussion 0 05-25-2008 05:06 PM
Do power zoom lenses work with K100D Super Monza76 Pentax DSLR Discussion 1 11-04-2007 01:24 PM
All times are GMT -7. The time now is 01:38 PM. | See also: NikonForums.com, part of our network of photo forums!
