Originally posted by audiobomber Any idea how it attaches to the camera? My biggest beef is that the neck strap is horrible to attach and detach and the wrist strap is at least as bad. I'd like to be able to switch carrying systems more easily.
Hi audiobomber,
I use Camdapter bases and grip straps, but will temporarily attach a neckstrap if I need to use both hands. I've attached swivel clips at the ends of the neckstrap and a triangular split ring on the left side strap attachment point. I can attach both ends of the neckstrap to the ring, and the camera hangs left side up.
Before anyone objects that this would be awkward, realize that I only use this to free both of my hands without putting the camera down and leaving it unsecure. If I'm shooting, the camera is in my hand, with the Camdapter grip.
If you want to be able to use the neckstrap with the camera hanging normally, you need to install another split ring along with the grip strap on the right strap notch, then you can attach one of the clips without having to take the grip strap off.
I've attached a couple of quick shots to illustrate one of the clips I use and the split ring on the left side.
Scott
