Originally posted by Dubious Drewski After shooting a wedding two nights ago, I went home and tried to take my AF540 flash off of my K7 body, but it's stuck. It's very severely stuck. This flash has been difficult to take off before, but after some muscle, I have been able to free it. But not this time. I have been wiggling, retightening/untightening, yanking, pulling, grunting and cursing, and none of it is working.
Has anybody heard of this happening? I fear that if I continue to muscle it too hard, I'm going to actually break something.
This is, as you will have noted from the other replies, not an uncommon problem. However, here is one method to try to get the flash off the camera without surgery, and if it works, good!
- Unlock the flash with the lever
- Push the flash hard forward (toward the lens)
- Turn the camera hot shoe down
- Play with the lock lever
- Gently pull the flash off.
The only time mine stuck this worked. I suspect that I had pulled the flash so that the pin was binding in the hot shoe. Before I put the flash on the camera again, I am going to remove the pin.
