06-03-2007, 05:57 AM   #1
K10D Iso setting when using Flash 540
I usually shoot in P mode with auto Iso set between 100-800 or 100-1600.
If I shoot with the flash 540 I get pictures taken with the max ISO setting allowed 800 or 1600 is it normal?
should the K10 software not "select" automatically either the lowest or in between iso?
looking forward your answers.
(made a search prior posting but could not find an answer)
Michel
May Pentax be with us (and produce more lenses)
06-03-2007, 06:08 AM   #2
Lowell Goudge's Avatar
QuoteOriginally posted by Mitch34 Quote
Michel
There is a previous thread about this. If I recall correctly, the camera in auto mode will try to adjust first to the natural light setting.
I usually shoot with the flash in manual mode, which by default does not have auto ISO.
you can also set user mode to be what you want for flash settings
06-04-2007, 12:03 AM   #3
blende8's Avatar
That's correct.
It is nevertheless slightly annoying, because one can forget about this behaviour.
To prevent this I have chosen to shoot with flash in M only, where it either goes back to ISO 100 automatically, or I can set the desired ISO by hand.
camera, dslr, flash, iso, photography
K10d: Manual ISO setting in Aperture Priorty Mode bkhphoto Pentax DSLR Discussion 10 09-20-2013 08:15 AM
Using K10D with a P-TTL flash - what setting? ScotIslander Pentax DSLR Discussion 3 04-30-2010 10:55 PM
K10D+540 flash problem using trailing flash wirelessly PaulT Flashes, Lighting, and Studio 4 01-18-2010 10:00 AM
K10D+540 flash using trailing flash wirelessly PaulT Troubleshooting and Beginner Help 2 01-15-2010 03:01 AM
Ok, I got the 540 flash with my K10D..... sharpshoota Pentax DSLR Discussion 19 02-08-2007 11:38 AM
All times are GMT -7. The time now is 01:45 AM. | See also: NikonForums.com, part of our network of photo forums!
