11-04-2009, 01:03 PM   #1
Thinking of switching from km to k10d??
I have a km and have played with the kx, both great cameras. One thing that I don't like are that there is no viewfinder indication of which auto focus point is being used, generally not much of an issue usually shooting center anyway but can be annoying when tracking moving targets. Also the lack of hard buttons. Especially for metering and auto focus modes. I really like how the K10/20D are laid out. In fact im considering selling my km to pickup a k10d I found for only 350$. Im not a very experienced photographer but I find myself switching between spot and area metering alot and center and multi point auto focus these options are all menu based on km/kx. I would love the K7 but not im my price range.
11-04-2009, 01:06 PM   #2
Eruditass's Avatar
Pasted:
You can assign the green button, next to your right index finger, to do center-AF point.
When it is set up like this, you push that with your index finger, then push the 4-way pad with your thumb, and focus, no extra button pushing. You have a maximum of 3 quick button pushes to reach any focus point (green, and 2 direction pushes), and you always know where you are when you push the green button. You don't have to push OK or anything.
Worked pretty well for some action shots I was taking.
As for changing the metering method, I find it pretty simple especially now that the e-dial can change the setting when hovering over it. Hit info, go to metering, move e-dial. To change again, hit info, move e-dial. Works with any setting including auto-focus mode (though I pretty much only use select AF point). If you set green button to center focus, using the e-dial switches between modes. Then hit info and its still on metering mode, use e-dial to change that.
11-04-2009, 01:08 PM   #3
Eruditass's Avatar
Also, the main things I missed when moving from K10D that I used for a while to K-x is 2 dials and weathersealing. I used the second dial to change ISO a lot.
However, with the newer interface of the K-x, I find it a non issue. You add one extra button - right d-pad button goes instantly to ISO. And you can use the e-dial then to change the ISO (either max ISO if auto ISO is selected or the fixed ISO).
No weathersealing was expected of course :\
Everything else I find great on the K-x.
11-04-2009, 01:58 PM   #4
If you can't afford the K-7 and you really need the extra buttons plus focuspoint indicator I think the K20d will be a better buy than the K10d, K20d prices have come down a lot.
11-04-2009, 02:00 PM   #5
Jasvox's Avatar
or you can buy my K10D...Pristine for $425 with Grip.
Jason
11-04-2009, 02:07 PM   #6
Im using the km. No green button just help which can't be setup to change auto focus. also no point selection just center or multi.
11-04-2009, 02:10 PM   #7
I like the 20d but from what I hear the improvements from k10d are minimal not to mention its still about three times the price.
11-04-2009, 02:13 PM   #8
Eruditass's Avatar
My first post is in reference to the K-x, The K-m does indeed not have that capability.
k20d is like $500 refurb, or K-x range for new. Biggest change is the sensor and then theres other things like lens-specific AF adjust.
11-04-2009, 02:17 PM   #9
k20d for 500$ on ebay?
11-04-2009, 02:19 PM   #10
Eruditass's Avatar
Every so often this pops-up:
https://www.pentaxforums.com/forums/pentax-dslr-discussion/75597-bestbuy-has-...-499-00-a.html
You could also get them in the marketplace for around that price used, often with accessories. But the price on the K20D used here fluctuates a lot.
11-04-2009, 02:20 PM   #11
Andi Lo's Avatar
Picking K10d you'll notice the drop in AF speed... and it's quite a bit. Just to let you know
11-04-2009, 02:24 PM   #12
Eruditass's Avatar
Also, I believe the K20D is also slower (though not as slow as the K10D) than the K-m/K-x
11-04-2009, 03:33 PM   #13
Im in canada. Bestbuy does not carry pentax here . K20d slower than km? I find that hard to believe.
11-04-2009, 04:42 PM   #14
Andi Lo's Avatar
QuoteOriginally posted by jonnyp Quote
K-m is the first pentax that got AF really right in low light... Which is probably the reason I dont have a K20d yet.
In good light from hearsay they should be about equal. In fact in good light K10d is already very good imo.
11-04-2009, 05:12 PM   #15
creampuff's Avatar
K-m to K10D is a big time regression imo.
auto, camera, center, dslr, focus, im, km, photography
I'm thinking of switching to Nikon.. help (!?) Lauke_101 Non-Pentax Cameras: Canon, Nikon, etc. 15 08-20-2010 11:44 AM
Thinking of switching from Comcast to Verizon FIOS MRRiley General Talk 5 04-14-2010 08:38 AM
For Pentax users who changed systems or thinking about switching rustynail925 Pentax DSLR Discussion 34 03-04-2010 01:22 AM
thinking of switching my DA*50-135 for new Sigma 18-250 OS HSM laissezfaire Pentax SLR Lens Discussion 6 03-30-2009 07:51 AM
Considering switching from 40D to K10D amyandmark3 Pentax DSLR Discussion 9 01-02-2008 08:13 AM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, part of our network of photo forums!
