Originally posted by TimothyB Ah, I guess maybe one thing I didn't consider is that the shutter is still the mechanism to control the length of the exposure, like say that 1/60th of a second as mentioned. I first figured thought the sensor exposure was controlled digitally, like an on/off switch.
Yup, you're correct. the shutter is held open before / after the exposure so that the live view feed can be clocked off the sensor, which is achieved with an electronic "shutter" since the mechanical shutter couldn't move fast enough (and would wear out too quickly).
For the actual exposure though, the mechanical shutter is used. The main reason for this is that the exposure is still adversely affected by light falling on the sensor while being read out. Hence higher image quality is achieved by closing the mechanical shutter so as to end the exposure during read-out.
Noise will still be significantly lower during a live view exposure though, because only the shutter mechanism needs to be triggered. The mirror remains raised the whole time, and that removes a significant portion of the noise normally heard during a non-live view exposure.
