09-09-2006, 08:49 AM   #1
Shake reduction & camera life
I was just thinking, with the sensor moving up and down and back and forth at a high rate of speed (like 1000 rpms siting on Jannamans tractor), I wonder what the life of the cables that connect the sensor to the body.
09-09-2006, 09:21 AM   #2
Tony's Avatar
QuoteOriginally posted by Brew1brew Quote
Have no idea but it certainly isnt something i would lose any sleep over
09-09-2006, 06:30 PM   #3
No idea but...
I probably won't worry too much. I know Pentax's SR is different from KM's AS but it is similar from what people have been saying. And KM has been using the technology for a while now and we have still yet to hear such breakdown from KM cameras.
cheers,
Kenny
09-09-2006, 08:58 PM   #4
QuoteOriginally posted by kjao Quote
cheers,
Kenny
I'm not really worried about it. I'm an engineer in telecom and work with new tech all the time. It's just a thought about what could fail. I will be buying a k10d some time in the next year. And think the SR is a great idea. it's just the engineer in me was wondering how long the conductors will last when they are being moved back and forth.
Les
09-10-2006, 06:14 PM   #5
Arpe's Avatar
Just like the cable to my CD player tray becane disconnected with the tray going in and out all the time. Time will tell.
09-10-2006, 11:52 PM - 1 Like   #6
And if the sensor will shake off dust at every lens change that shouldn't make things last much longer either...
Wim
09-11-2006, 08:57 PM   #7
Has it been made known what distance the sensor travels in shaking its bootie?
The magnitude of the oscillation might help put the likely wear in perspective?
Of course, also, might there be a chance that the connections are designed as spring contacts? Even though introducing electrically noisy connections would then seem likely?!
09-12-2006, 09:31 PM   #8
Looking at the sensor assembly:
...the connectors are bundled together and look as though a fair length has been used such that the movement wouldn't stress the wires too much at any specific point. Of course, if they resonated enough (like a guitar string) then perhaps you'd have problems pronto, but we'll assume that that's been anticipated and avoided, hopefully ;-)
09-23-2006, 10:16 PM   #9
Ole
Ole's Avatar
Pentax has now posted some detailed information on the system:
http://www.pentaximaging.com/files/product/PENTAX%20SR%20Description_091506.pdf
09-27-2006, 05:58 AM   #10
Sensor moves on a very short distance, less than a cable thickness. So there is no problem IMHO.
camera, dslr, life, photography, reduction & camera, sensor
camera shake reduction Wes Pentax DSLR Discussion 26 04-20-2010 12:19 PM
M42 lens' & shake reduction Big Bob Troubleshooting and Beginner Help 11 06-14-2009 06:49 AM
Using long telephotos & Shake reduction mr.voigtlander Pentax DSLR Discussion 28 06-04-2009 11:56 PM
K10D, Shake Reduction & Tripod switch79 Pentax DSLR Discussion 28 04-19-2007 06:18 PM
in-camera shake reduction vs in-the-lens WMBP Pentax DSLR Discussion 17 02-23-2007 09:13 PM
All times are GMT -7. The time now is 04:40 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
