11-08-2009, 07:36 AM   #1
tele_pathic's Avatar
K200D: Problem with manual focus
Morning all. I have a problem with my K200D that I recently bought used. I can't use the MF. AF works fine, but there are occassions, albeit few and far between, when I need to use MF. However, whenever I manually focus the lens, the pic is always out of focus. This happens with every lens. I had lasik a few years ago, so I know it's not my eyes.
I adjusted the diopter adjustment on the top all the way to the right and no improvement. After a bit of research, I found that the diopter adjustment comes in different "sizes," or whatever. Do I need a different diopter adjustment thingy? Where would I get one and how would I know which one to get?
The guy I bought the camera from changed the focus screen to something, and then changed it back when I bought the camera. Could that be the problem? Any help is appreciated.
Thanks,
TP
11-08-2009, 08:49 AM   #2
StevenVH's Avatar
Hi, i used a K200 until recently and for MF accuracy I had to have split -image focussing screen and an eyepiece magnifier (O-ME53).
If your vision is "normal" you should be able to use the stock eyepiece diopter.
You can check the Pentax site for accessories or some of the bigger online retailers, your local camera store may be able to order accessories for you too.
I'd suggest doing the brick wall and/or newsprint tests or something similar to help diagnose your issues.
Also, did you turn off the shutter release AF function? Or at least switch the camera to MF? If not, when you press the shutter the camera tries to re-focus.
hth
11-08-2009, 11:46 AM   #3
My previous K200D works fine with MF.
I only use the center point. need a little bit patience.
11-08-2009, 10:05 PM   #4
Marc Sabatella's Avatar
QuoteOriginally posted by tele_pathic Quote
OK, but are you saying that moving the diopter all the way to the right is the correct setting for you? Do the numbers at the bottom of the viewfinder appear in focus at this setting?
Yes, if he installed the focus screen improperly, that would make MF not work right. I'd let someone else try (and be sure to set the diopter properly for their eyes first).
Note it is normal when shooting at large apertures (f/2.8 and below) for the viewfinder to show more in focus than will be in focus in the picture. But there should be nothing in focus in the picture that was not also in focus in the viewfinder.
adjustment, camera, diopter, dslr, focus, k200d, lens, mf, photography
Problem with manual focus noabsolutes Pentax DSLR Discussion 14 06-18-2010 06:27 AM
manual focus problem col48 Troubleshooting and Beginner Help 2 04-07-2010 03:15 AM
Manual focus problem with K10D? yyyzzz Pentax SLR Lens Discussion 8 12-01-2009 05:50 AM
Manual Focus with the K200D atyab Pentax DSLR Discussion 8 12-30-2008 02:12 PM
Problem with Manual Focus K100D brupa82 Pentax DSLR Discussion 11 06-15-2008 12:18 AM
All times are GMT -7. The time now is 03:42 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
