06-04-2007, 08:47 PM   #1
SR and MLU
While shooting long exposures on a mountain river I discovered that the K10D doesn't let you combine SR and MLU (2sec timer). If you turn on MLU it automatically turns off SR.
Does anyone know why this is? I find MLU helpful on long handheld shots to isolate the shake of pressing the shutter button and the mirror moving up from my shot. Using SR would just improve this.
I was mostly shooting at 1/6th to 1/3rd of a second, outside of the range of what is ideal for SR. Some have one second exposures such as this one:
This is a more typical 1/3rd of a second exposure:
I checked the custom functions, but I'm not running the very latest firmware. Have they changed this?
alex
06-04-2007, 09:46 PM   #2
Can't answer your question unfortunately, but just wanted to say I loved the pics!
06-04-2007, 10:51 PM   #3
It is because mirror lock-up is supposed to be used when camera is mounted on tripod and when camera mounted on tripod shake reduction shouldn't be on. So, Pentax made assumption that when 2 sec. timer is activated, camera is on tripod ant K10D turns SR off by itself.
I like this feature very much, without it I would forget to turn off SR most of the time while taking pictures from tripod
06-05-2007, 03:50 AM   #4
mattdm's Avatar
Not a solution but a minor workaround -- one thing you can do is shoot in continuous drive mode and hold the shutter for two shots, then discard the first.
06-05-2007, 07:44 AM   #5
Matjazz's Avatar
QuoteOriginally posted by mattdm Quote
In this case the mirror slaps each time.
06-05-2007, 08:11 AM   #6
Buddha Jones's Avatar
Bulb mode?
06-05-2007, 08:13 AM   #7
ISH
ISH's Avatar
Looking at your photos, I don't see what the problem is. Your photos look great, who needs SR if you are getting results like this. The second one is just AWESOME!
06-05-2007, 08:36 AM   #8
mattdm's Avatar
QuoteOriginally posted by Matjazz Quote
Yeah, of course it's only partial -- it at least reduces movement from the shutter press.
06-05-2007, 10:36 AM   #9
QuoteOriginally posted by ISH Quote
Thanks the compliments. I can hold a camera reasonably still, but SR still helps eek out a bit more. I had to discard about half of the shots due to camera shake.
I'm disappointed that they don't allow you to turn off the SR defeat through a custom function. Using MLU really is a helpful trick for long exposures.
The K10D is much better than the *ist D for handheld versions of these photos due to ISO 100 (allows for longer shutters in good daylight) and SR.
There are more photos here:
AlexAndChristine : photos : Lena Lake -- June 2007 - powered by SmugMug
I brought along 4 lenses, but primarily used the DA 14 and DA 21 for these shots.
alex
06-05-2007, 11:14 AM   #10
The SR turning off might actually be helping your shots turn out.
I've noticed some of my pic's where I was fully braced have been a little blurred, and the camera shops daughter noticed the same thing.
The theory that they came up with was the camera creates the same shake that it has on the tripod.
Since they came up with that theory we've all tried turning the SR off for those pic's where we hardly move, and all our consistency has improved.
camera, dslr, exposures, mlu, photography, sr
Mirror up (MLU) on the K7 - Who's using that ... jpzk Pentax DSLR Discussion 16 09-18-2010 07:09 PM
Kx - MLU w/ bracketing? bnorikane Pentax DSLR Discussion 8 12-24-2009 12:29 PM
67 MLU Question. Swift1 Pentax Medium Format 1 09-08-2009 07:51 PM
Pentax 6x7 non MLU Mark S. Pentax SLR Lens Discussion 0 11-16-2008 10:42 AM
All times are GMT -7. The time now is 06:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
