Originally posted by Class A It doesn't on my K100D.
While the minimum shutter speed changes with the focal length, the shutter speed chosen by the camera ranges between that minimal shutter speed and 1/180 depending on ambient light.
OK, the camera does increase the shutter speed to adjust exposure vs. ambient if the light is bright , but the point is still that with Flash on in Av mode , Program Mode, Green Mode etc, the camera
doesn't care about underexposure vs. ambient.
That's just standard flash exposure logic - Canon and Nikon cameras behave exactly the same way - I've frequently used a Canon 40D and 50D
Originally posted by Class A So the camera will increase the shutter speed from 1 sec to 1/60, perhaps. That's still slow-speed-sync, or not?
No, that's not slow-speed-sync vs. the technical definition because the camera is compensating against camera shake, not against flash or ambient exposure. If the room is completely dark, or the subject exceeds the flash maximum range, the shutter speed will still be 1/60 secs.
Because of the insignificance of the shutter speed for flash exposure, in Tv mode, one is setting the ambient exposure only and asks the camera to match the flash exposure to that. In Av mode, one would be setting the flash exposure only and would be asking the camera to match the ambient exposure. I don't see why one mode (Tv) would make sense, while the other does not (Av).
What am I missing?
You just need to understand that normal flash exposure and slow-speed-sync exposure operate on separate and distinctly different rules.
