01-09-2010, 07:59 PM   #16
QuoteOriginally posted by pbo Quote
There are two guides on internet about how to change the screen. One is on Katzeye's site - which, IMO, makes the process seem easier than it actually is. Another one is closer to reality, and though it is written in poor Engrish, it's quite generously pictured - here on focusingscreen.com instructions section
I had several problems while installing the screen. First one - latch was a bit hard to open. Then, the screen can wiggle around in the chamber before locked down - so you have to juggle a bit with twizzlers to get the screen into place (once in place, it will stay there). And finally, the screen seems to be a bit thicker than original - the latch lock doesn't click in as nicely as it does with original
It was a bit tiring process for me - since I also tried different combinations of shims and such - but once I got it all figured out, screen is a joy to use. So far, I haven't even missed AF brackets much. But even if I need to guesstimate the AF points - I have the grid.
Hi,
I am interested in that same screen. Does it come with all the shims and what not or does it just come with the screen with no shim? If so, where do you get shims to try out with?
thanks
03-29-2010, 01:42 AM   #17
Kx interchangeable focusing screen?
Hi,
It came along with 2 shims and the focusing screen, I took about 10 mins to select one shims and place the focusing Kx-K3 and lock it back which is not too difficult.
During installation, when placing the shims, you should look at the view finder to ensure that it is in position before placing the FS, the first time I did not check and just place the FS and lock back, look throu the view finder and saw the shims was not properly sitting in position, unlock and adjusted it and after all this, I am very please with this Kx-K3 focusing screen.
It has solve my focusing problems cos I do not have very sharp eye.
Hope this info will help you too.
03-29-2010, 06:25 PM   #18
hi guys, i got dust and stuff in my focus screen after trying to "clean" it.
how do i remove the focus screen so I can clean it?
I don't have those special tweezers that come with new ones
camera, dslr, kx, photography
Focusing manual lens with OEM focusing screen, is a split screen really needed? skid2964 Pentax Camera and Field Accessories 16 09-17-2010 02:54 PM
For Sale - Sold: Minolta X-700 Focusing Screen (for you to cut your own split screen) frank Sold Items 3 09-24-2009 10:08 PM
PZ-1 interchangeable screen aybee34 Pentax Film SLR Discussion 1 05-24-2009 05:45 PM
K20D and interchangeable focusing screen wildman Pentax DSLR Discussion 1 06-12-2008 08:44 PM
K10D interchangeable focusing screens and warranty question. pentaxbling Pentax DSLR Discussion 2 11-20-2007 02:04 PM
All times are GMT -7. The time now is 08:39 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
