11-19-2009, 11:26 AM   #16
reeftool's Avatar
No, I didn't really notice the exposure differences until afterwards. My daughters crew team had several boats entered in what is called a "Head" race where each boat is started 10 seconds apart and the start time of each boat is recorded and the time of finish a few miles down the river and often the faster boats overlap and there isn't much time to check things. I did check a few shots for exposure and check the histogram, usually the final shot of a burst and they looked ok. Afterwards, I noticed the random dark shots. I understand entirely how the exposure changed with spot metering but was puzzled on why the data was the same. On the later shots taken with the Pentax lens, I got the same results but data that matched the exposure. I always (or I should) use center weighted metering at these events. Reading off the rowers and boat, matrix metering picks up on the water and reflected sunlight and makes crazy readings and a burst with spot metering will change exposure as the it will read differently on the dark brown uniforms or skin. It only happened once and when I spot metered by accident. I did not switch metering modes until after I uploaded my card and saw the mistake.
08-03-2010, 09:22 PM   #17
I know this thread is really really really old. But since the issues I had with the Bigma. I ordered a DA*300 and have shot at least a 4000 images in the same conditions as I would shoot with the Bigma and I have yet to get a dark photo and like I said that is in at least 4000 images. I'm wondering if maybe something is going wanky with the Bigma. I know since I have had the DA*300 the Bigma hasn't been out of it's case. And yes the camera's are on roughly the same settings as when I was using the Bigma. I just wanted to let everyone know what I have found out. I'm not saying anything bad about the Bigma.
Jim
08-03-2010, 09:28 PM   #18
I would put money on this needing a shutter replacement. Have had the same, and seen the same thing. Same settings - some shots just coming out very underexposed. Shutter is gone.
Whoops just noticed this is old.
08-04-2010, 08:09 AM   #19
paperbag846's Avatar
I had a similar problem when I had "exposure compensation" in the custom settings turned on. Exposure compensation with spot metering could be disastrous. Not sure if the exif would record the changed settings.
camera, dslr, home, image, photography, races, shot, shots
Nature On the Dark Side - 5 Pictures Tamia Post Your Photos! 4 11-05-2010 07:31 AM
Dark purple pictures from K-X luma Pentax DSLR Discussion 7 09-20-2010 03:07 PM
K7 wont take pictures in dark?? XeroX Pentax DSLR Discussion 14 08-03-2010 04:41 PM
Pictures too dark Sargmaster Pentax Camera and Field Accessories 9 12-15-2009 03:53 AM
Pentax K10 - dark pictures Maros Pentax DSLR Discussion 22 07-29-2007 11:52 AM
All times are GMT -7. The time now is 06:22 AM. | See also: NikonForums.com, part of our network of photo forums!
