11-18-2009, 07:39 AM   #1
Mark Morb's Avatar
K10D AF Adjustment?
I'm beginning to suspect that my K10D is having slight AF issues.
I've had it more or less since they launched the K10D and I've since invested in some higher quality lenses etc.,
I've been finding it increasingly hard to nail the focus using any of my FA Ltd AF lenses, frustratingly so...and I've been looking at the images at 100% and it looks to me as though the camera is focussing slightly "behind" the point that I want it to....not by much but as I usually shoot at a large aperture for narrower DOF it is quite noticeable.
Is there any way of adjusting this? I've looked throught the settings but can find nothing...
Maybe now is the time to upgrade to the K7 after all....
Thanks,
Mark
11-18-2009, 08:35 AM   #2
Wheatfield's Avatar
Use this at your own peril.
K10D Focus Error Adjustment |Photography Rulez
Also, some clever Korean guy with too much time on his hands figured out the button sequence to get into the K10 debug mode.
Of course he published it to the net so Pentax removed the possibility with a firmware update.
So it goes.
But if you are on the original firmware, you might be able to dig around with google and find reference to it.
11-18-2009, 08:44 AM   #3
Mark Morb's Avatar
So it goes.
Hmmm.....I'm on the latest firmware...
11-18-2009, 09:42 AM   #4
Here's a direct link to the PF thread about K10D debug mode, including s/w download link and link/instructions for entering/exiting debug mode using a simple text file.
FWIW, I've downloaded, scanned for malware, installed, scanned for malware again, used the software, and scanned for malware once more and everything worked just fine -- no problems, no malware, and fixed a slight BF issue I had. (That said, I don't know if the current download is the same as the one I grabbed, so best to take appropriate precautions or use the text file method.)
I also had better results with this focusing test method than the common angled charts. YMMV.
11-18-2009, 10:06 AM   #5
Mark Morb's Avatar
Thanks for the link to that thread. I shall give it a go tonight....
12-01-2009, 02:41 AM   #6
Mark Morb's Avatar
Thanks for all the help with this...succesfully adjusted the AF by +80. Went out over the weekend and it's like having a different camera, much sharper images.
Thanks again everyone...
af, camera, dslr, k10d, k10d af, lenses, photography
K10D focus adjustment with debug mode cem.kumuk Pentax DSLR Discussion 12 01-16-2016 07:11 PM
[K10D] focus adjustment per lens sterretje Pentax DSLR Discussion 12 03-18-2010 08:33 AM
AF adjustment - am I doing it right? jesalonen Pentax DSLR Discussion 15 01-31-2009 07:37 AM
New K20D doesn't seem as sharp as my old K10D... AF adjustment needed? Richdog Pentax DSLR Discussion 20 12-27-2008 06:38 AM
K10D Viewfinder indication adjustment ? ukbluetooth Pentax DSLR Discussion 5 02-29-2008 03:01 PM
All times are GMT -7. The time now is 05:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
