11-18-2009, 04:50 PM   #1
skid2964's Avatar
Best of the *ist series?
There was a thread on this about a year or so ago, I cannot find it.
I want opinions on which Pentax *ist DLSR was the best and why.
It may be an un-fair question since the D was a pro camera and the rest were not, all opinions and comments are welcome.
11-18-2009, 06:45 PM   #2
The DL is the only *ist series camera I've owned. The 6mp sensor's support was nicely dialed in at this point, so it seems very close to the K100d in picture quality - and it's one of the few *ist cameras with a 2.5" viewing screen (along with the DL2 & DS2). A solid picture taker & very easy to use. My daughter took our DL to the Galapagos Islands & returned with some excellent photos, and the camera has continued to work flawlessly after lots of heavy use. A definite thumbs up for the DL!
11-18-2009, 07:23 PM   #3
HogRider's Avatar
I have had several cameras from the *ist Series. Personally I would say I liked them in that order and why:
1. *ist D (2 wheels, battery grip, super smooth shutter, Penta Prism)
2. *ist DS2 (Penta Prism, large LCD screen)
3. *ist DS (Penta Prism)
3. *ist DL (Penta Mirror)
11-18-2009, 09:38 PM   #4
artemapei's Avatar
I would vote for DS
11-20-2009, 04:55 PM   #5
*ist choice
If you don't manual focus, the DL would be fine. If you do use manual focus (ie: A series lenses) then you'll probably prefer the prism finder to the mirror finder. Definately a D if you can find one at your price, otherwise a DS or DS2 depending on availability. I got lucky about a year ago and found a DS from a dealer with a new camera warranty! The DS2 offers the bigger LCD, but I don't consider that much of a plus. Anyway, I'm happy with my DS - 6 mp is fine.
Al
11-20-2009, 05:09 PM   #6
raymeedc's Avatar
I've used, & been satisfied with, a pair of DS bodies for years. So far, I haven't felt a compelling need to move up to a newer model. The only thing that made the D a "pro model" as you've deemed to tag it, was the inclusion of two wheels to control shutter & aperture selection during full manual metering mode, as opposed to the one with a button on the DS, if this is a determining factor for you. I personally do not find it to be better or worse, just different, & I use this feature quite often.
11-20-2009, 05:37 PM   #7
Lowell Goudge's Avatar
*istD without a doubt
clearly the *istD is the best even with it's small buffer slow write speed and small screen.
Big plusses,
dual whumb wheels
penta prism
TTL Flash metering
11-20-2009, 08:03 PM   #8
Banned
I have the DS2 with penta prism and I like the larger 2.5" LCD than the D or DS and TTL flash mode for my AF400T and AF500FTZ.
11-20-2009, 08:13 PM   #9
raymeedc's Avatar
Big plusses,
dual whumb wheels
penta prism
TTL Flash metering
Not so clear to me. The DS has the same TTL flash metering capabilities & the same Pentaprism, with a larger buffer area & screen, uses more modern SD cards and, as I stated above, the dual wheel vs. single wheel setup is a matter of preference (IMO), and of no consequence at all if you don't use the full manual metering mode often.
11-20-2009, 08:17 PM   #10
QuoteOriginally posted by raymeedc Quote
Not so clear to me. The DS has the same TTL flash metering capabilities & the same Pentaprism, with a larger buffer area & screen, uses more modern SD cards and, as I stated above, the dual wheel vs. single wheel setup is a matter of preference, and of no consequence at all if you don't use the full manual metering mode often.
which is where my *istD spends most of it's time
Note also the DS is a little on the small side,
Even the *istD is a relitively small camera, when you consider coming from a fill sized monster like a PZ-1.
11-20-2009, 09:06 PM   #11
raymeedc's Avatar
E
Another matter of preference. I love the small size of my DS. Among other benefits, it allows me to easily carry two bodies at once, making my habit of shooting with primes almost exclusively a much more efficient matter, not having to continually change lenses. I keep one with a permanently mounted M42 adapter for my screwmounts, while the other handles my SMC Ks.
11-20-2009, 10:03 PM   #12
doc.mark.dimo's Avatar
My pick... the original *ist D
I loved the Original *ist D for several reasons...
1. proprietary hyperprogram features with twin dials (opposed to other *ist's on the series)
2. battery grip option
3. dreamy Sony 6mp sensor (although I never use the D, i miss the output from this sensor, can't really describe it, its just different)
I never use it, but I keep it as a collectors item and for the nostalgia it brings
11-21-2009, 07:47 AM   #13
*ist DS.
Its all I have used in the last 5 years. My first dSLR (coming from a ZX-5N QD), and I am not missing anything (yet). I don't have a strong reason to upgrade (yet). Its smaller size makes it the happy medium for my wife and me....
Swapping the focus screen is easy. Another plus, I think, if you like to shoot manual focus lenses or just like to focus manually.
There is some truth to what was tought to me a hile back: you could have a $50 lens and $1000 camera, or $1000 lens and $50 camera. The latter is the one to give you $1000 pictures (figuratively, of course, but you get the idea)
11-21-2009, 08:53 AM   #14
HogRider's Avatar
I can't believe no one who used the D mentions the super smooth shutter and mirror slap. My first DSLR was the *ist D and then I bought the *ist DS a little later as a backup body. When I took the first picture with the DS, I actually thought that thing was broken because of the loud shutter/mirror slap...
11-21-2009, 12:51 PM   #15
AMBIVALENCE's Avatar
Does all the ist use the same sensor from Sony?
*ist, camera, dslr, opinions, photography
Bogen 190 series and 055 series - advice needed geauxpez Pentax Camera and Field Accessories 9 12-16-2008 01:34 PM
Can I use smc Pentax-A lenses on my *ist D/*ist DS? Ole Pentax DSLR and Camera Articles 3 05-18-2007 10:23 PM
All times are GMT -7. The time now is 10:46 AM. | See also: NikonForums.com, part of our network of photo forums!
