11-26-2009, 09:02 PM   #76
Thanks ogl. Very interesting results.
I wonder if the Pentax engineers are experimenting with the A550 sensor at the moment. Potentially they may be able to do better things with it than Sony has done.
If Pentax use it, it will have to be suitable for video too.
11-26-2009, 11:37 PM   #77
I thought the Kx had the 550 sensor already?
There is more to it than just the sensor of course, supporting electronics around the sensor does contribute to the final image.
11-27-2009, 12:08 AM   #78
ogl
ogl's Avatar
Google Translate
interview with K-x's "fathers"
11-27-2009, 01:02 AM   #79
QuoteOriginally posted by WerTicus Quote
No, I believe the 'sister' sensor to the K-x is the sensor in the 12MP Sony A500. The sensor in the A550 is a 14MP one.
And yes, you are most likely right that a lot of the magic lies in the supporting electronics. The Pentax engineers and the PRIME 2 processor etc must contribute a lot to the capabilities of the K-x.
It will be great when the Imaging Resource guys test the Sony A500. Direct comparisons between the A500 and the K-x will then be possible.
11-27-2009, 01:19 AM   #80
QuoteOriginally posted by ogl Quote
Google Translate
Cool.
One thing I noticed straight away is that the engineers looked pretty young.
The other thing that seemed clear (as best it can via Google translate) was that their design process involved a big focus on noise management, from the electrical engineering of the circuitry ('To reduce the noise, or alternately compare Kaede also take small passive components, low noise throughout the circuit'), all the way through to the firmware, where they clearly wanted to make even 12800 ISO images a useful possibility, not an after thought.
I note they are also aware of user interest in the lack of super-imposed AF points in the viewfinder.
camera, dslr, k-x, lr, nr, photography
DA15 - where is good resolution? ogl Pentax SLR Lens Discussion 82 05-10-2009 06:46 AM
k20d \ k200d have a good noise reduction? platinum Pentax DSLR Discussion 4 04-20-2008 01:47 PM
ISO noise - pentax K10D is good? platinum Pentax DSLR Discussion 5 04-18-2008 03:24 PM
good low light zooms? goldfishin Pentax SLR Lens Discussion 10 06-14-2007 10:43 PM
All times are GMT -7. The time now is 03:35 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
