11-19-2009, 01:25 PM   #1
Manua Focus
Hello,
I have what is probably a dumb question. Can I still get focus confirmation(beeping sound) when I use a manual focus lens on my DLSR?
THanks,
Kevin
11-19-2009, 01:30 PM   #2
For Pentax DSLRs: YES.
11-19-2009, 01:32 PM   #3
Sorry I cant spell. Even for the basic K110D? Thank you.
11-19-2009, 04:32 PM   #4
Marc Sabatella's Avatar
There has never been a Pentax DSLR model without focus confirmation or in which focus confirmation stopped working just because you had a manual lens mounted.
11-19-2009, 04:36 PM   #5
Canada_Rockies's Avatar
Not to mention that every Pentax auto focus camera allows catch-in-focus, formerly snap-in-focus. Even with a manual lens installed, if the camera is in AF.S (single) the camera will not take an image until focus is detected. I use it occasionally even with my M 400, although the small aperture makes it less than optimal at dark times. I use it very often with my M 100 macro. Set the magnification on the barrel, hold the shutter release down, and sneak up on that bug.
11-19-2009, 05:14 PM   #6
As the others said, yes you can, but only the center AF point will give you focus confirmation, if you use a manual lens.
11-20-2009, 12:27 AM   #7
Please note that this will work only if your lens has a conductive mount plate.
If not, you'll either have to scratch its paint, or add some conductive material, so the camera's mount contacts are grounded.
Moreover, if you ground the A contact (the one slightly recessed), you'll enable P-TTL with those manual lenses, with some limitations (mainly with PK-M lenses, it works quite well with m42 lenses).
camera, dslr, focus, photography
Focus, Focus, Focus (or the usefulness of focus charts) GoremanX Pentax DSLR Discussion 31 12-21-2014 11:49 AM
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
Can a manual-focus lens have back focus problems? PocketPixels Pentax DSLR Discussion 33 02-13-2011 05:37 AM
K100D Super - Focus point locked to center in Manual Focus ? JGabr Pentax DSLR Discussion 2 01-25-2010 09:41 PM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
All times are GMT -7. The time now is 03:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
