11-20-2009, 08:55 AM   #1
How to use old pentax lenses on K-x?
I got a 50mm f2 pentax-A lens. I put K-x in Manual mode, enabled the option 22 in C menu. But all I can see is mirror flapping up and down, nothing else.
Could you please tell me what I am missing. What other settings I need to change?
11-20-2009, 09:19 AM   #2
QuoteOriginally posted by pjr Quote
What do you mean by this?
Generally, once you've enabled "Using aperture ring" in the custom menu and set the camera to manual, you set your aperture and shutter speed (either manually or automatically with the green button), focus, and snap away.
11-20-2009, 09:42 AM   #3
pjr
I did the following..
1. I put on the 50mm f2 pentax-A lens
2. Enable teh use aperture ring function
3. Switch off and on the camera
4. Camera asks for focal length.. I select 50mm
5. Now I can see F-- and shutter speed on the screen
6. When I press Green button and rotate teh wheel.. I can see the shutter value changing. (but view finder is dark -seems mirror lifted up and stuck there)
7. When I press shutter button.. I see brief movement of mirror then view finder is dark for a few seconds then mirror comes down.
8. After this..whatever button I press.. mirror keeps on going up and down.(even menu or directional buttons move the mirror)
11-20-2009, 09:48 AM   #4
Are you using LiveView?
11-20-2009, 09:51 AM   #5
pjr
no...
I was following these instructions..
K100D (Super) Pictorial guide to using manual lenses [imgs] [Page 1]: Pentax SLR Talk Forum: Digital Photography Review
11-20-2009, 09:51 AM   #6
Eruditass's Avatar
It should display the aperture with an A lens. Is your aperture ring in the "A" position and not one of the numbers?
11-20-2009, 09:58 AM   #7
pjr
Perfect... thanks
It was not on A. There was a small button to press to put it in A. I missed it.
Now it displays both aperture and shutter. Was able to take picture.
11-20-2009, 10:02 AM   #8
Eruditass's Avatar
Glad you found the problem! Enjoy!
11-20-2009, 10:02 AM   #9
pjr
Now the problem is I can only take picture at F2.0. Other apertures doesn't work
how to fix it?
11-20-2009, 10:17 AM   #10
gokenin's Avatar
are you saying that you cant control the aperture using the wheeldial on the camera to control the aperture? once its set to A thats how you control the aperture.
11-20-2009, 10:18 AM   #11
Eruditass's Avatar
In manual mode, you should be able to hold +/- and change the e-dial (or you can push it once to move the highlighted box to aperture).
In Av mode it should change it with just the e-dial.
What mode are you using?
11-20-2009, 10:21 AM   #12
pjr
I can change the aperture. But if I set to anything other than f2.0.. it doesn't take picture.
For example: If I set aperture to 2.8 or 4, when I press shutter button the viewfinder becomes blank as teh mirror flip up.. then it says for 3-4 seconds then mirror comes down. But no picture taken.
11-20-2009, 10:50 AM   #13
Eruditass's Avatar
Thats odd, what are the shutter speeds it says it will be shooting with?
Sounds like it is in self-timer mode when you do that. Does the same thing happen when you take pictures in LiveView?
11-20-2009, 10:53 AM   #14
Lowell Goudge's Avatar
With a manual focus lens with an A setting, the camera should be able to function (except for AF mode) as it would with the kit lens or any other AF lens.
From the description it sounds almost as if the camera is going into live view, You need to turn this off. I find on my K7 the live view button is a little too easy to push.
next , is the AF switch set to single, continuous or manual. If the AF is set to single, the shutter won't trip at all unless you are in focus. For manual focus lenses you need to be set to AF-C or AF off.
If you take the lens oout of the A position (and use aperture ring is set) then in Av mode the lens will only shoot wide open. In manual mode, you can meter by selecting DOF and adjusting shutter to match what ever aperture you have, or the AE button to stop the lens down, and take a reading.
11-20-2009, 11:07 AM   #15
pjr
I checked "self-timer" , set auto focus to "AF-C" , also camera is not in live view. Lens is in A setting.
Basically I can only take pictures at F2.0(max aperture). Any other aperture, camera gets stuck anywhere between 3-6 seconds and after that , I have to stop/start it. Otherwise it keeps on flipping the mirror up and down, no matter what button you press.
Also the shutter speeds are below 1 sec. 1/40th 1/100 etc. I am setting shutter speeds to these. (this doesn't matter to the camera if aperture is more than 2.0, it takes 3-6 sec and does nothing)
camera, dslr, pentax lenses, photography
For Sale - Sold: (3) Vivitar Series 1 70-210mm lenses + 3 Pentax lenses JP_Seattle Sold Items 13 04-23-2010 03:10 PM
Pentax Km and old manual lenses: SMC Takumars & Tamron Adaptall 2 lenses Kendrick Troubleshooting and Beginner Help 10 04-14-2010 03:23 AM
For Sale - Sold: FS: Pentax SF7-body / AF400FTZ / 3 Pentax-F lenses / GENUINE Pentax-accessori frederik9111 Sold Items 7 03-23-2008 03:00 PM
All times are GMT -7. The time now is 06:35 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
