03-15-2010, 06:17 PM   #46
https://www.pentaxforums.com/forums/pentax-dslr-discussion/93335-kx-focusing-screen.html
some images of the differnt screens.
03-15-2010, 08:16 PM   #47
I thought this DIY focusing screen tutorial was hilarious.
Just received my $20 focusing screen from Ebay Hong Kong. Here are my thoughts:
Pros:
1) Cheap; $20
2) Bright
3) Works well
Cons:
1) Slow shipping; more than 2 weeks to NYC, that's expected I guess
2) Crappy tools, the metal tweezer can very easily scratch the focusing screen, the plastic one broke
3) Crappy instructions, pretty much had to figure everything out on my own
4) The focusing screen has very mild stains on it. Not noticeable when a lens is attached but it looks like a water drop got on it.
Edit: WOW, had to make +80 adjustment in the AF debugging screen, possibly 90 to be on the safe side. Check the link here if you ever use the split prism focusing screen, they always need calibrating.
5) Did not come with shims, right now it is front focusing by a tiny bit, will have to calibrate with my own shims.
I'm dissatisfied enough to complain to the seller for selling me one that has mild stains on it. HOWEVER, for $20, the value is extremely good compared to the $100 Katzeye focusing screen. There's absolutely no reason to pay $100 for something that can be had for $20. I would buy again in a heart beat.
03-15-2010, 10:54 PM   #48
frank's Avatar
QuoteOriginally posted by hangu Quote
AFAIK, AF adjustment has nothing to do w/ the focusing screen you installed.
I got the Taiwan focusingscreen in my K7, the split is just a tad bit off. Can't put another shim on top of the screen 'cause it's gonna make the focusing even worse. Probably should take out the existing shim and put in a thinner one ...
03-15-2010, 11:40 PM   #49
I suspected as much after playing around with it for an hour. Thanks for confirming it. Although, I can't say I'm entirely happy about the focus indicator, I feel that's off by a bit at times. Do you think the Katzeye one will not have th same problem?
QuoteOriginally posted by frank Quote
03-16-2010, 02:17 AM   #50
frank's Avatar
As I said before, the focusing screen doesn't play any role in auto focusing. It doesn't matter which screen you install. You can use your camera in AF even w/o the focusing screen installed.
So no, the Katzeye screen won't help you at all in AF (the focusing indicator). It only helps for manual focus.
03-16-2010, 05:26 AM   #51
i got the same small problem with katzeye and my k-7(it's a little front focusing). however i went to local pentax service and ordered a collection of original shims for 20$, i hope there won't be much of an isue to calibrate it.
03-16-2010, 05:58 AM   #52
I use a different method than he shows in the video, mainly to avoid the sharp knife slipping.
But it is easy to experiment with different types of screens. I can pick up junk cameras at the fleamarket.
03-16-2010, 06:39 PM   #53
hnikesch's Avatar
I installed a split image screen (from china) on my KM and after playing with shims it works well with my manual lenses. I also use it as a AF conformation to make sure the camera picked the focus point I wanted.
03-18-2010, 03:21 AM   #54
I recently tried to "clean" my not dirty at all mirror + focus screen. Now its got some dust and some sort of "hair" AAARGH! it's ultimately annoying.
I don't have the special tweezers, any suggestion on how I can remove the focusing screen so I can wash them?
03-18-2010, 05:24 AM   #55
Jodokast96's Avatar
QuoteOriginally posted by TheEstablishment Quote
Thanks for the info JP. Have you noticed any issues with metering with the eBay screens?
I used one for a while. Metering was fine................until I tried to use either of my 2 flashes on it (a 360 and a 540). Auto worked fine, but P-TTL would underexpose by a minimum of 3 or 4 stops.
03-20-2010, 09:42 PM   #56
This thread encourages me to stay with the stock K-x focusing screen. A little too much confusion for me.
04-07-2010, 10:35 PM   #57
i think it shares the same focus screen with km
04-08-2010, 04:13 AM   #58
Am tempted to try one as am having trouble focusing with my manual lenses but the process / video does seem a bit daunting.
Read through this post but am having some difficulty understanding the "shims" part - I thought it was just replacing the focus screens - what's with the "shims" again, briefly ?
04-08-2010, 05:33 AM   #59
QuoteOriginally posted by knoxploration Quote
Correct, it's not intended to be user-replaceable.
The screens can be replaced . . .
04-08-2010, 10:35 AM   #60
QuoteOriginally posted by felixkh Quote
If you'd read just two posts further down the page before replying, you'd have seen that I was alerted to that five months ago, and apologized for the mistake at the time. (Nowhere in the user manual or their websites does Pentax note that the K-x/K-m screens are interchangeable).
camera, dslr, focus, k-x, photography, screen
K-x focus screen drawing & Travor focus screen issue xjx Pentax DSLR and Camera Articles 2 06-06-2012 10:13 PM
Focus screen help couliseaux Pentax Camera and Field Accessories 2 06-12-2010 11:10 PM
Focus screen chromo Pentax DSLR Discussion 8 03-03-2010 06:12 AM
Quick Question: Pentax KM screen replaceable with split-focus screen? vinzer Pentax Film SLR Discussion 2 01-06-2009 01:21 AM
Focus Screen code4code5 Pentax DSLR Discussion 2 01-20-2008 10:00 AM
All times are GMT -7. The time now is 08:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
