11-22-2009, 04:07 PM   #1
Pentax K-7 and 1hour 20 minutes night exposure
I have made long exposure test with my K-7.
Parameters:
ISO 100
Sigma 10-20/4-5.6 lens at f10
1hour 20minutes exposure time
Result is here:
Iīm very pleased with result, as there are no purple areas, as I have read something about chip overheating.
After capturing the image camera was performing Dark Frame Substraction, I was expecting it will do it about same time (1h 20min).
But it took only about hmm 20 minutes? I donīt know exactly.
Do anybody know how DFS time depends on shooting time?
11-22-2009, 04:15 PM   #2
hot damn! thats awesome, nice work!
11-22-2009, 04:40 PM   #3
kent's Avatar
how did you manage to get 1 hour 20 min exposure?
11-22-2009, 05:04 PM   #4
er1kksen's Avatar
QuoteOriginally posted by kent Quote
Bulb with the remote or something similar, I would assume.
Is there any way to view a larger version of the image? It's hard to really get much out of such a small, compressed image but what I can see certainly looks promising.
11-22-2009, 05:14 PM   #5
yeatzee's Avatar
QuoteOriginally posted by er1kksen Quote
I concur 123456...
11-22-2009, 05:43 PM   #6
Ash
Ash's Avatar
I've reviewed this result and your comment with interest therion.
I'm more keen to see the image in better JPEG quality posted in a larger resolution linked to a photo hosting site for more detail. Reason being that at this quality and low resolution, there is no way of telling how well the K-7 performed in controlling noise for this long exposure.
You mentioned a short DFS time, which indeed does seem unusual. It does appear that the exposure time you reported is right (judging by the FL you used and arcs created by the stars) but there isn't any explanation I can think of to understand the quick DFS processing time - unless somehow the K-7 accelerates DFS exposures (anyone attest to this phenomenon?)
My interest is in finding a way to create controllable noise in low-ISO long exposure images from the K20D/K-7 CMOS sensor, as it has not been a positive point for these cameras (cf. the K-x, which seems to do reasonably well).
My paltry attempt at long exposure with the K20D failed miserably (excuse the blur):
https://www.pentaxforums.com/forums/post-your-photos/74773-night-country-trai...iso-noise.html
Even with strong NR performed, I couldn't get results even close to those from my CCD-driven K10D:
This by the K20D:
This by the K10D:
11-22-2009, 05:51 PM   #7
arbib's Avatar
WOW....Fantastic.....
The Aussie night shots are quite interesting with the circular motion of the stars...
11-22-2009, 06:47 PM   #8
I've done a ~90 minute exposure with my K-7 and IR remote, although nothing worth showing here as cloud cover came in partway through, so I only continued the exposure out of mild curiosity. Pretty sure my DFS was identical in length to the main exposure, though. Can't see how they could accelerate it, as dark frame noise is dependent on shutter speed - so if the DFS frame is shorter, the noise pattern won't entirely match.
I'm wondering if one of two things happened here: Either the OP ran low on battery and hence the camera terminated the DFS exposure early so the file could be written before the camera powered off, or (less likely) the sensor passed the overheating threshold during the DFS frame and terminated the exposure for that reason.
11-22-2009, 06:52 PM   #9
okay so i know how you did it in practise, but HOW on earth do you know that you need 1h 20mins of exposure.
is there some sort of calculation? i thought remote-bulb shots were hit and miss. but how can you afford to take a +1hr picture not knowing if its even going to come out properly.
11-22-2009, 07:01 PM   #10
QuoteOriginally posted by therion Quote
Your observation is correct.
I noticed the change after upgrading to Firmware V1.02
Prior to this, and for all previous Pentax cameras, DFS time = Actual Exposure time.
I think Pentax has tweaked the V1.02 firmware with some "intelligent" algorithm assessing how much DFS time is actually needed for noise control, and it usually comes out quite a lot less than Actual exposure time
But Pentax didn't mention anything about it
I took several rounds of Bulb Mode shooting to confirm that, but I think that's right.
Some results I got
Exposure 10 secs , 3 Secs DFS
Exposure 1 minute, 20 Secs DFS
Exposure 10 minutes , 3 minutes DFS
I know the theory is that you have to match the exposure time for DFS to match the noise pattern, but the "accelerated DFS" doesn't seem to have hurt the image quality.
11-22-2009, 07:51 PM   #11
Ash
Ash's Avatar
QuoteOriginally posted by PNTXFTW12 Quote
There's nothing really to calculate.
In pitch black darkness, ambient light is negligible and at low ISO barely registers in the scene. What matters is the stars etching their path on the sensor, and this may require a relatively large aperture, but their brightness will not be dependent on shutter speed, but rather the ISO and aperture.
Foreground exposure will then be determined by whatever little ambient light there is available - or you can create your own.
11-22-2009, 07:52 PM   #12
Ash
Ash's Avatar
QuoteOriginally posted by kittykat46 Quote
Some results I got
Now that's interesting - and a welcome improvement (if indeed it gives the same results as an equal DFS to exposure time).
11-22-2009, 08:35 PM   #13
Jodokast96's Avatar
I think he may have been more concerned with the exposure of the ground as opposed to the stars.
11-23-2009, 12:37 AM   #14
I have measured right exposure by this procedure:
I have set K-7 to ISO 6400, f4 aperture on Sigma, tried several exposure times, I was most happy with 15sec
So here is calculation:
First ISO:
6400 3200 1600 800 400 200 100
15s - 30s - 1min - 2min - 4min - 8min - 16min
and now aperture:
f4 f5.6 f8 f9.5
16min 32min 1hour 1hour 30min
I have used external programmable cable release, set time to 1hour 20min (I would like have it darker). Set to Bulb a and fired.
(I have updated K-7 to fw 1.20 before.)
After 1hour 20min I have taken camera home and thought I will wait long time, as K-7 should perform DFS the same time. But I was surprised very much when about 20minutes it has finished.
So it really seems so Pentax has changed DFS to shorter, more accaptable way.
OK I will post full image.
11-23-2009, 02:41 AM   #15
First ISO:
and now aperture:
f4 f5.6 f8 f9.5
Interesting... I thought I updated my firmware before my long exposure, but maybe it was the other way around. Time to do another long exposure, methinks.
Elegant way of figuring out a suitable exposure time, btw!
1hour 20 minutes, camera, dslr, exposure, k-7, k-7 and 1hour, minutes, pentax k-7, photography, result, time
Landscape Star Trails (night exposure) Marc Langille Post Your Photos! 42 01-07-2010 03:58 AM
I just noticed this with my recent long night exposure shot.... vmax84 Troubleshooting and Beginner Help 22 08-17-2009 04:44 PM
night exposure mettering problem lukas Pentax DSLR Discussion 6 09-11-2008 10:27 PM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
Zurich by night II (K10D, 3 long exposure pics) tcom Post Your Photos! 0 12-12-2006 03:29 PM
All times are GMT -7. The time now is 09:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
