11-23-2009, 03:42 PM   #1
Horizontal Lines - Help
Greeting all,
A search did not show my exact problem but if I missed it please forgive me.
My 4 y/o *istDS has been producing shots with horizontal lines across the frame. Its mostly in the center of the frame and is evident in the two pics attached.
I thought is was ISO related as its more noticeable in high ISO shots (Sample 2 = ISO 1600) but Sample 1 is at ISO 200 so that's not it. I've changed mem cards, downloaded straight from camera (not card reader), cleaned everything I can but it seems to be internal. I'm guessing sensor.
Can it be repaired? Does it make sense to repair it? (I'm over 10K shots with the DS). Where can/should I send it?
Thanks,
yustr
11-23-2009, 04:16 PM   #2
is it intermittant or permanant? My guess is unreliable contact of connector between sensor and main board and you need to take apart and clean contacts on connector(s).
11-23-2009, 04:46 PM   #3
It looks like a "wet sensor cleaning" that went bad. Like when using a wet swab with not enough (or too much?) cleaning solution. The cleaner dries before removing all the gunk.
11-23-2009, 05:52 PM   #4
Its intermittent and the sensor has never been cleaned wet (nothing other than a spray of air.)
Any other ideas?
Thanks
11-23-2009, 06:24 PM   #5
QuoteOriginally posted by yustr Quote
Any other ideas?
Thanks
Intermittent does suggest a dry contact somewhere. I had similar issue on my ist DS.
11-23-2009, 07:44 PM   #6
QuoteOriginally posted by MSsuper Quote
i...you need to take apart and clean contacts on connector(s).
Is that something I can do or does it need to go out? Is there a guide available?
11-24-2009, 08:39 AM   #7
You can do if you're handy with a screw driver. Repair guide at http://www.pentax-hack.info/firmware/k10_gx10/older_sm.zip
11-24-2009, 12:40 PM   #8
Thanks MS but it appears to be beyond what I'm comfortable trying.
Anyone have repair shop recommendation?
yustr
11-24-2009, 05:58 PM   #9
tomwil's Avatar
I remember reading about a symptom similar to this, I believe over at DPR. The thread found that radio interference was the culprit, which was intermittent.
EDIT:
Here is one thread about RF interference possibly caused by cordless phones, cell phones, wireless routers, TV/Radio towers, and such: http://forums.dpreview.com/forums/readflat.asp?forum=1036&message=22883293&changemode=1
Also, some pictures of RF interference here: http://www.dpreview.com/reviews/panasonicdmcl1/page18.asp?color_compare=pentax_k10d/0
11-30-2009, 08:59 AM   #10
Anyone have a recommendation on a repair facility? Also, what is the cost just for them to "have a look"?
11-30-2009, 10:12 AM   #11
Lowell Goudge's Avatar
it's hard to tell whether this is banding or just the inability to correctly resolve the changes in shaded regions.
I looked at the two examples, and I can see banding, but it looks like it is the result of seriously pushing shadow detail.
Note that the resolution, i.e. the grey scale value per F Stop becomes non linear at about +/- 2.5 stops. SHadow detail has less resolution per stop and can be prone to banding, especially if there is some background pattern that is roughtly horrizontal
camera, dslr, frame, iso, lines, photography, sample, shots
Horizon not parallel to horizontal borders Furansu Photographic Technique 9 06-06-2010 08:55 PM
Horizontal or Vertical Jools Photographic Technique 10 05-16-2010 12:26 PM
Stitching software - Vertical and Horizontal Jasvox Digital Processing, Software, and Printing 8 04-30-2010 05:30 PM
horizontal bars in video jeans Video and Pentax HDSLRs 10 12-20-2009 01:23 PM
Horizontal lines on K10D? mgarbutt Pentax DSLR Discussion 11 04-01-2008 06:03 PM
All times are GMT -7. The time now is 11:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
