11-26-2009, 12:01 AM   #1
flockofbirds's Avatar
something about the flash
So when I take a picture with my k200, mounted with my M 50 1.4 and I use the built in flash. The flash seems to be... extra bright, and drowns a lot of things out in white. Is do I need to manually adjust the flash or something? I've messed around in the menu but didn't find anything.
I assume this problem is coming from the inability for the camera to communicate with the lens?
11-26-2009, 12:51 AM   #2
You're right, P-TTL flash works only with A lenses...
With PK-M and m42 lenses, it will just fire at full power (quite strange they didn't allow a power setting...).
There is a mean to enable P-TTL with those manual lenses, but it works only with stopped-down lenses, meaning that you'll compose with a darkened viewfinder (there is a trick with PK-M lenses to use them as stop-down lenses) : shorten the A contact of the mount, and then select the widest aperture possible on the camera (not the lens itself!).
11-26-2009, 12:53 AM   #3
Ah, alright. Thanks for the quick reply.
11-26-2009, 01:03 AM   #4
QuoteOriginally posted by flockofbirds Quote
...I assume this problem is coming from the inability for the camera to communicate with the lens?
Exactly. Inability to both communicate with and control the aperture of the lens. So you get the built-in flash just pumping out a flash at maximum output. You will need to manually calculate the appropriate aperture to use on the lens based on the ISO you are using, and the flash to subject distance.
How to calculate this is described in the K200D manual on page 132.
But the basic formula for the aperture to use is guide number divided by shooting distance in metres. Since we know at 100 ISO the guide number of the flash is 13, then for example a subject 3 metres away would mean we need to set an aperture of f4.3, or close enough (eg f4) on the manual lens.
11-26-2009, 01:35 AM   #5
Okay, seems simple enough for me haha. I'll have to try this out sometime tomorrow, but I will probably just switch to a DA lens if I am gonna use the flash because this full flash drains the batteries quite quickly. But good to know if I need it.
Thanks.
camera, dslr, flash, photography
Sigma 530 Super flash doesn't fire multi flash, any advice? pasipasi Pentax DSLR Discussion 4 11-25-2010 02:04 AM
For Sale - Sold: Metz 48 AF-1 Flash; Pentax off-camera flash cable set (Adapter F, FG (US/UK/CA bigben91682 Sold Items 4 10-12-2010 04:23 AM
Basic Pentax K-x, hot-shoe, flash, flash bracket, wireless question MrPetkus Flashes, Lighting, and Studio 5 04-27-2010 10:57 PM
For Sale - Sold: Pentax AF200S flash, Vivitar 2800 macro flash, Lowepro Lens case 4 Light_Horseman Sold Items 8 03-06-2010 10:13 AM
For Sale - Sold: Pentax TC's, Kenko TC, SF10 (x2), AF540 flash, Promaster FTD 7000M flash Marc Langille Sold Items 17 08-16-2008 10:29 AM
All times are GMT -7. The time now is 02:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
