11-27-2009, 08:06 AM   #1
K7 Exposure...
To all and especially Falk
Have you noticed an exposure difference between the k7 and other cameras?
There is a thread on DP which indicates that the k7, at a given ISO, will require 1/2 stop more light.
I have run tests comparing my k10 to the k7 in a controlled environment and have noticed this as well. Gordon Good, EE extrondinaire, seems to think that the K7 exposes to the right to make up for black read noise. Much of this discussion is captured in the thread below. My moniker in that forum is Yesman.
K-x vs K-7, without K-7 ISO cheating: Pentax SLR Talk Forum: Digital Photography Review
To me, what matters is that I am able to capture an image with a given fstop and shutter speed which results in a image with good quality wrt to noise et al.
Thus if the k7 requires more ligh to achieve this objective, it is not desirable and effectively derates the ISO. However, I have often had to dial in +EV compensation on the K10 so I am not sure yet if the issue is the difference in metering or the effective ISO of the K7.
Thoughts:?
11-29-2009, 07:21 PM   #2
Bump....has anyone measured the exposure differences between the K7 and other cameras
11-29-2009, 08:02 PM   #3
Wheatfield's Avatar
The K7 exposes more accurately than any Pentax DSLR before it. A half stop is SFA in the real world. Go and take some pictures and stop worrying about trivialities.
11-30-2009, 02:36 AM   #4
Wouldn't this also depend on lens used ? I recall vividly when i tested my Sigma 18-50mm macro 2.8 vs Tamron 17-50mm 2.8 lens, the Sigma always gave me more overall light and working faster shutter speeds at the same iso/aperture, than my Tamron. For that reason I chose my Sigma for indoor low light shots more than my Tamron.
11-30-2009, 03:25 AM   #5
QuoteOriginally posted by eva2000 Quote
I've did some quick tests with my K7 Tamron 17-50 2.8 vs my K100D with the 18-55 kit lens, and when using the same apertures and iso, the K100D always gave me a faster shutter speeds and sharper pictures in low light situations.
I have yet to test the two bodies with the same lens.
11-30-2009, 05:30 AM   #6
Hi Eva2000 and mindglow
In both cases I used a 50mm A series lens opened to 1.7 to ensure that the lens was not the determining factor.
11-30-2009, 05:45 AM   #7
pcarfan's Avatar
QuoteOriginally posted by spartan Quote
If you check the histogram and find the K-7 histogram shifted to the right by half a stop, then it is fine. If the histograms look identical (not the shape, but the horizontal position), then the K-7 is indeed gathering less light.
This is not perfect, but is a bit better than just going by the readings alone.
11-30-2009, 07:17 AM   #8
jeffkrol's Avatar
Are these yours?
Have you tried this at low iso's?
I'd be interested in the results here and w/ a lens other than the 50 because anomolies do show up at wide open w/ these lenses (fast lenses).
Soooo just reproduce this at say iso 200 and an f4 lens....
12-02-2009, 07:42 PM   #9
Yes those are my tests of K10 and K7 under same lighting conditions converted with RawT. set to neutral
Nick
12-02-2009, 07:53 PM   #10
Gordon B Good says that the K7 over exposes and then decreases by a little over half a stop to decrease dark read noise (this is apparently automatic with ACR). Certainly seems like he knows what he is talking about, but it is over my head. I guess if you want to, you can shoot manual and force whatever shutter speed, iso and aperture you want to. It would probably look about the same, but with more noise in the shadows.
camera, dslr, forum, image, iso, k-7, k10, k7, noise, photography, thread
Help with exposure Grazy81 Troubleshooting and Beginner Help 12 08-05-2010 08:42 PM
Exposure. sebberry Troubleshooting and Beginner Help 5 11-20-2009 08:09 AM
what don't I get about exposure? FHPhotographer Pentax DSLR Discussion 34 09-11-2008 07:12 AM
Night photography with K10D - High ISO short exposure VS Low ISO long exposure pw-pix Pentax DSLR Discussion 10 02-03-2008 01:37 AM
I need some help, WB/Exposure? Drinksmixer Pentax DSLR Discussion 2 07-13-2007 10:15 AM
All times are GMT -7. The time now is 10:06 AM. | See also: NikonForums.com, part of our network of photo forums!
