12-01-2009, 01:08 AM   #1
K7 and Wireless bug?
Hello!
I'm trying to use the wireless feature with a K7 and a sigma 530 super...
It works great, but the on-board flash is still lighting the scene, although I set option 31 (Flash in Wireless mode) to "off" (built-in flash as control flash).
This option has no effect whatsoever...
Anyone has the same problem?
12-01-2009, 06:28 AM   #2
Wheatfield's Avatar
Just a dumb question, but is the wireless flash triggered optically or by a radio signal?
12-01-2009, 06:43 AM   #3
boesgaard's Avatar
@Wheatfield: Wireless flash is triggered by the onboard flash.
12-01-2009, 09:18 AM   #4
you're always going to get some contribution from the onboard flash because you're catching the tail end of the control signal. Nikon/Canon systems have the same issue...but they have an IR only commander you can buy...
12-01-2009, 09:30 AM   #5
If the camera is set correctly, the control signal should not contribute to the lighting of the scene. Sorry OP, I'm not familiar with the K-7, so I can't tell you if the setting you quote is the right one.
12-01-2009, 09:32 AM   #6
From memory (and from a careful reading of Pentax' own P-TTL patents), all informations are actually sent before the shutter is actuated, even the delay to be used for second curtain...
So, the on-board flash should be non-effective during the shutter actuation... But I can be wrong.
Anyway, I'm not talking about a faint ghost of flash (as would be the case of a tail end of the control signal), but of absolutely no difference between the two modes!
12-01-2009, 10:15 AM   #7
I think Pentax made some change to the wireless protocol on the K-7. The only way I can use it is if I have another Sigma flash on the hot shoe to work as controller. It doesn't work with the on board flash.
12-01-2009, 11:13 AM   #8
I think I can confirm the problem, even though the only flash I own (a Sigma EF500 DG SUPER flash) does not actually work wirelessly with the K-7.
Simply taking two pictures of myself in front of a mirror, with custom option 31 successively set to each of its possible values (and flash set to wireless, of course!), produces identical images, and the pop-up flash is clearly lit during the exposure in both cases.
Looks like a bug to me, hopefully one that can be fixed in firmware.
12-01-2009, 12:28 PM   #9
tomtor's Avatar
QuoteOriginally posted by RBellavance Quote
With my K10 and AF540 or Metz58 you can see that the (pop-up) flash still emits some light even when it's just a controller. This is normal. It's the final control flash that you see, but it's much less bright than when you use the pop-up in the normal mode.
You should check the difference not in the mirror but by taking an image. With the popup flash as a controller you'll see a single shadow, from the remote wireless flash, in the normal mode you should see two shadows.
12-01-2009, 01:16 PM   #10
QuoteOriginally posted by tomtor Quote
That is somewhat hard to do, given the fact that I don't have a flash that is wireless-compatible with the K-7 (it did work fine with the K10D).
I suppose the fact that there is no off-camera flash might confuse the P-TTL system, and that invalidates my test.
12-01-2009, 01:33 PM   #11
stormcloud's Avatar
not having this prob with my k7 and sigma 530 super - might be a tiny contribution but its very minor - certainly its just tail end of the flash and and not full blown effect
12-01-2009, 01:43 PM   #12
Well, I've run the tests again, and no matter what settings I have in Custom 31, the on-board flash still lights the scene the same way...
It's not a matter of the control flash being "accidentaly" recorded by the camera, as I've tried with varying ISO settings with the same exposure from the on-board flash, so it had clearly compensated (if that was only the control flash, its presence would have been more or less visible with the ISO change)...
12-01-2009, 03:51 PM   #13
Ash
Ash's Avatar
Has this issue not been discovered until now?
Seems unreasonable for the K-7 not to be able to trigger a wireless flash unit with its on-board flash. K10D and K20D have had no problems doing this...
That would have to be a priority firmware update for Pentax.
12-01-2009, 04:14 PM   #14
QuoteOriginally posted by dlacouture Quote
Try one of these, Nikon | SG-3IR IR Panel for Camera Built-In Flashes
Thank you
Russell
12-01-2009, 04:20 PM   #15
K10D have had no problems doing this...
Wrong answer. When the Sigma EF 500 DG Super came on the market, it didn't work in wireless mode with the K10/20D. It had to be sent back to Sigma for a "re-chip" that made it compatible with the new(er) Pentax cameras in wireless mode.
camera, dslr, flash, k7, option, photography
Macro Bug buskel Photo Critique 1 06-18-2010 01:31 PM
Another K7 Bug? mcjm78 Pentax DSLR Discussion 4 08-02-2009 08:22 AM
My best bug yet... heliphoto Post Your Photos! 5 07-20-2008 02:01 PM
Name this bug ... ukbluetooth Photographic Technique 13 06-19-2008 08:17 PM
All times are GMT -7. The time now is 06:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
