12-01-2009, 05:54 PM   #1
Photoshop CS3 won't open Kx PEF files
Is there a Camera Raw update that I'm missing (I currently have 4.6)? Is there any other software I can use to open the files?
Thanks, Romeo
12-01-2009, 06:16 PM   #2
flockofbirds's Avatar
You could try using the included Pentax Software.
12-01-2009, 06:44 PM   #3
alohadave's Avatar
There's no support for K-x RAW files in Camera Raw yet (currently 5.5).
Even so, you'll need to upgrade to CS4 to use ACR 5 or higher.
http://www.adobe.com/products/photoshop/cameraraw.html
12-01-2009, 06:49 PM   #4
QuoteOriginally posted by RomeoCrugnale Quote
Thanks, Romeo
ACR is up to 5.6 RC1 nowadays. It fully supports K-x PEF.
http://labs.adobe.com/wiki/index.php/Camera_Raw_5.6
If you save your RAW files in DNG format in-camera instead of PEF, you could probably open them even with ACR 4.6, although I am no Adobe expert.
And yes, if your ACR doesn't work, use the supplied Pentax software to open your PEF's.
12-01-2009, 06:52 PM   #5
Wheatfield's Avatar
Thanks, Romeo
No. Camera Raw for CS-3 ended at 4.6, IIRC. It will not ever be able to open files for any camera that came after that update. This is why I shoot DNG. I don't have to worry about which Camera Raw I am using.
Adobe has a free DNG converter which will conveet your K-x PEFs to DNG, which you can then open in CS-3.
Personally, I'd just start shooting DNGs and make your life easier.
12-01-2009, 06:59 PM   #6
deejjjaaaa's Avatar
Thanks, Romeo
1) LR3 Beta is free and you can use it for quite some time ... also there are free raw converters like Rawtherapee (read their forum first - the last version needs some extra step to work normally) and UFRaw, etc... if you are on Mac there is a Mac only RPP which is good... finally there are things like Picasa and so on.
2) you can convert PEF to DNG or shoot in camera DNG - but ACR v4.6 is 2 generations old (ACR v5 and LR3 Beta - 2 generations) anyways so why do you want to use a subpar raw conversion ? if you are inclined to use Adobe raw conversion - get LR3 Beta.
12-01-2009, 07:59 PM   #7
Wheatfield's Avatar
QuoteOriginally posted by deejjjaaaa Quote
1) why do you want to use a subpar raw conversion ?
You've said this in another thread and I challenged you to come up with some sort of evidence that the newer ACRs were significantly better than 4.6 at raw conversion.
I haven't checked recently, but I kept an eye on that thread for a few days and you never did come up with an answer.
I am still switching back and forth between CS3 and CS4, as I prefer CS3 for a few tasks. So far, I haven't seen any difference at all between the renderings.
CS4 does offer a few more cool options, but the renderings themselves don't seem different to my eye.
So, what am I missing, pray tell?
12-03-2009, 10:09 AM   #8
Gir
Either shoot DNG or (I've given up shooting DNG because the K10D doesn't use compression with DNG so I use PEF to save card space (about 50% more picture/card) and convert them to DNG when importing in LR 1.3 (DNG compression is the applied)) use Adobes free DNG converter.
A friend of mine has thee same problem with his E-620. PS CS3 won't open the raw files and was about to shoot JPEG only when I caame up with this idea. He downloaded the current version and it works. It's a step more, yes, but this saves you some money. Give it a try.
Ah, DNG compression is lossless.
camera, dslr, files, photography, photoshop cs3
How to batch rename files after files imported and tagged in Photoshop Elements raider Digital Processing, Software, and Printing 5 03-14-2013 10:36 PM
Pentax Kx - PEF Files - CS3 jk333 Pentax DSLR Discussion 30 11-27-2009 12:26 PM
Photoshop CS3 won't open K20d PEF files GeneV Pentax DSLR Discussion 4 06-26-2009 04:47 PM
CS3 plugin for PEF boyscout Digital Processing, Software, and Printing 1 03-05-2009 06:41 AM
PEF files for the K10D and Photoshop CS???? HELP! jstlilome Pentax DSLR Discussion 8 04-03-2007 01:35 PM
All times are GMT -7. The time now is 07:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
