12-02-2009, 12:38 AM   #1
k20d high speed flash sync
Hi, i want to know what does this function mean exactly, does it mean that by using an external flash of any brand, the sync speed can be more than 1/180?
the manual says that using a af540fgz you can sync faster, but it doesnt say if using another flash it will work... my nikon d70s syncs until 1/500s with any brand...
12-02-2009, 05:52 AM   #2
Dom
Guest
Good question I'm going to have to have a go with my sigma flashes and see how high I can go.
12-02-2009, 06:01 AM   #3
It also works with Sigma and Metz dedicated flashes.
12-02-2009, 11:13 AM   #4
i use a nikon speedlight sb 26, but i cant try it till next week...
12-02-2009, 11:49 AM   #5
Ash
Community Manager
Ash's Avatar
It wouldn't be a Pentax-dedicated flash and so I'm not sure this flash would give you HSS with your K20D.
HSS enables you to use flash at shutter speeds as fast as you like, the flash compensating for the shorter shutter speeds by increasing output to adequately illuminate the scene in the mode.
It's useful for adding fill flash in already well-lit scenes.
Look down below at the similar threads section for more details...
12-02-2009, 12:26 PM   #6
noblepa's Avatar
Actually, I thought that HSS decreases the flash output.
The normal sync speed of 1/180 second is the fastest speed in which the shutter is completely open. At faster speeds, the trailing curtain begins closing before the leading curtain has completed its travel, resulting in a moving slit across the sensor.
A normal flash usually has such a short duration that it won't be on for the entire time that moving slit makes its way across the sensor. This results in unexposed sections of the image.
With HSS, the flash unit flashes multiple times, as the slit moves across the sensor. These flashes are too close together for the human eye to distinguish the individual flashes. HSS requires that both the camera and the flash unit have the capability and that they speak the same language to each other. IOW, not all flash units will do HSS with a Pentax camera.
12-02-2009, 12:45 PM   #7
Moderator Emeritus
That's true and also I doubt that the Nikon would do that either with any brand or model. The flash and camera need to talk to each other because the flash it sync'd to the travel of the curtan.
The output is greatly reduced because the flash has to fire almost continuously as the shutter curtain moves. To do this there's no time to recharge the flash and it is using only the stored charge. So it might have to fire 4 times for the exposure (a guess), thus each flash will be approx 1/4th the output of a full power shot at 1/180th
12-02-2009, 12:48 PM   #8
QuoteOriginally posted by Peter Zack Quote
I was just wondering how my d70s can sync at 1/500...
12-02-2009, 01:00 PM   #9
Ash
Community Manager
Ash's Avatar
Points taken Paul - you're right.
gybp - your Nikon D70 is able to HSS with your Speedlight because they speak the same language.
Pentax and Nikon don't communicate well together if at all (that says a lot) but a Pentax-dedicated flash that does speak the same language as Pentax cams can sync up to 1/4000 secs.
12-02-2009, 01:04 PM   #10
Moderator Emeritus
QuoteOriginally posted by gybp Quote
Probably because (I have not researched this) that the camera goes into a different mode at higher sync speeds. Instead of taking the shot and the shutter curtain moving across the sensor. The shutter remains open and the sensor turns on and off like a P&S camera would. Same way all these DSLR's are shooting video now at 24 and 30 FPS. It's an "electronic" shutter.
12-02-2009, 01:11 PM   #11
i always shoot manual mode
12-03-2009, 12:10 PM   #12
noblepa's Avatar
The D70, unlike most dslrs (even most Nikon dslrs) has an electronic shutter, in addition to the mechanical focal plane shutter. I believe that, when synching at higher speeds, the D70 actually holds the FP shutter open longer, and uses the electronic shutter to sampe the sensor data for a shorter period of time.
But, then, I don't own a D70 and I am not an expert on them. My brother does own a D70 and a D200. The D200 can "only" sync at 1/250, because it lacks the D70's electronic shutter.
camera, dslr, flash, photography, sync
K20D High Speed Shutter Flash Sync ?? WalterGA Pentax DSLR Discussion 7 11-04-2009 10:23 AM
high speed sync MGV Pentax Camera and Field Accessories 1 10-23-2009 11:44 PM
high speed sync DanLoc78 Pentax Camera and Field Accessories 5 10-01-2009 04:26 PM
K20D High Speed Sync Question thomps6s Pentax DSLR Discussion 15 12-03-2008 09:48 PM
Flash high speed sync. Deni Photographic Technique 22 08-26-2008 02:35 PM
All times are GMT -7. The time now is 12:32 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
