Originally posted by doggy1972 You really seem to have a vibrant music scene there. The last shot is very good. The grain can be seen in the light about the horn players head but, it looks very organic and non digital.
Thank you for your kind comments.
Yes, around here there is music every night of the week - more to the point, music I like and "worthwhile", my "record" stands at 24 gigs in one week... which means that I could see/hear and photograph 4 acts in one night.
I've shot at the dark jazz club for nearly 2 1/2 years now, so the musicians and venues are used to me.
So I get to process a lot of photos, but my pp is not very sophisticated, and very simple minded
- all I used to do was resize, adjust brightness/contrast and sharpen and that was it.
(I shoot almost exclusively JPGs at 10Mp, 2 star ).
However at the jazz club the lighting is very contrasty -
going from bright at stage center, to almost no direct lighting on other parts of the stage,
and even darker off stage where musicians play,
and a lot of the interesting action takes place.
Even at stage center where there is enough light for almost "normal" shots the lighting is pretty contrasty and harsh when falling on the wrong place
The last shot that you mentioned started like this:
EXIF attached - ISO5000, f/4.5, 1/50; 68mm -2/3 comp
Although there was good light - the player stepped back so that his face was out of the circle of light, and his shirt (which contained a lot of white) was in the main spot light - so one can see the contrast problem. I shot at -2/3 compensation (Highlight Correction On, and Shadow Correction on Low).
Straight brightness/contrast adjustment would blow the shirt out - not that that was important - but as pointed out to me elsewhere this can be distracting, even if it kind of conveys the scene. So I resorted to curves in Tone Map (in my olde editor Ulead PhotoImpact 8)
instead of the classic S shape all I did was to pull the middle up:
which brought up the face without blowing out the bright parts of the shirt.
I then fine tuned the brightness/contrast to what pleases my eye.
I am not very precise nor "repeatable"
- since I do everything by eye.
