Hi there,
Just thought I'd add my own comments with regard this AF issue.
I also worried about the AF issue for a while before getting the Kx. It does seem a slightly odd omission to provide 11 AF points but then not give any visual indicator in the viewfinder of which point has been selected by the camera.
However, now that I have the camera, I have been able to compare it with my old and trusted Nikon D40. The D40 has 3 AF indicators spread fairly wide apart in the viewfinder. I quickly discovered that to have them all active was a waste of time as it would invariably select the wrong one when focusing. I thus resorted to the single centre point for all my photos - using the old and trusted technique of focus and recompose as discussed elsewhere in this post. Now, compared to the Kx, I do have to say, in the first instance, that it is helpful to have that indicator in the viewfinder right in front of you on the main screen, even if one is only selecting the centre point for all photos - not least because I wear glasses which makes seeing the green focus indicator at the bottom of the Kx screen slightly more problematic. On the other hand, my comparisons with the D40 has not thrown up any problems with regard focus issues with the Kx. It nearly always produces well-focused shots.
So, to sum up, I don't see the point of having 11 AF points if no visual indicator is provided in the viewfinder to indicate which point has been selected. To my mind, one might just as well have a single centre point since that is all one can rely if one uses the viewfinder for composing and focusing - I have no experience of the live view mode which probably does provide more focus-related help to the user.
One final point, I wonder if it would have been perhaps better if the camera's viewfinder had shown the focus points themselves, rather than the slightly quirky combination of square and ordinary brackets which one can see in the viewfinder. It isn't easy to see from these various brackets where the points are exactly.
Mike
