12-07-2009, 04:49 PM   #1
ea77's Avatar
K-X front / back focus correction, lens tested
There's a correction feature on K20D and K7.
K-X I haven't seen one.
Noticed some soft shots not properly focussed shots with a FA 50mm 1.4, daylight and night. Set to center focus.
Anyone notice this as being a problem or is every AF lens working perfect on the K-X body?
12-07-2009, 05:53 PM   #2
Marc Sabatella's Avatar
No, there is no adjustment feature on the K-x. It's normal for cameras other than the K-7 to FF slightly in tungsten light, but if you are seeing FF of more than a millimeter or so in *controlled testing*, then your camera is defective and should be returned under warranty. However, I can't emphasize those words strongly enough "controlled testing", meaning you have taken careful and extensive steps to be sure the problem is not a simple matter of the amera choosing a different point to focus on than what you intended because the AF sensor is much broader than just a "point". I'd wager that 99% of all reported focus problems are just a case of the user not carefully controlling the test well enough. There has to be *nothing else* anywhere *near* the center of the picture in order to be sure the camera really picked the exact spot you intended.
12-07-2009, 06:52 PM   #3
deejjjaaaa's Avatar
QuoteOriginally posted by ea77 Quote
debug mode
Pentax Kx / Pentax K-x AF adjustment through undocumented "debug mode"
12-07-2009, 06:56 PM   #4
I've tried about 8 lenses on my K-x, including the FA 50mm 1.4. No perceptible BF/FF to report with any of them so far. However I try not to confuse missed focus with FF/BF.
I have had lots of missed focus shots, especially under challenging light, or where I haven't been able to build up the DOF to a useful range, or where the subject was very busy and the AF latched on to the wrong area of contrasting detail, or where I've been unable to manually focus.
camera, correction, dslr, focus, k-x, k-x front, lens, photography, shots
Front/Back Focus issue - Is it the camera's problem or is it the lens? vtqanh Pentax DSLR Discussion 10 09-26-2012 04:58 AM
So how can a lens affect front/back focus? klh Pentax SLR Lens Discussion 16 10-03-2010 05:18 AM
Trying to understand front focus/back focus thing 41ants Troubleshooting and Beginner Help 16 08-31-2010 08:42 AM
would a manual lens experience front/back focus problems? blu3ness Troubleshooting and Beginner Help 8 11-04-2009 11:14 AM
Front focus/ back focus on Manual lens. Possible? WangJianWei Troubleshooting and Beginner Help 6 04-20-2009 07:50 PM
All times are GMT -7. The time now is 09:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
