Dear all,
after years of pondering whether or not to buy a DSLR, I decided to buy a K-x. It arrived yesterday. I spent the evening learning the basics about its use, shooting some pictures with the inlcuded kit lens. So far, so good - and no battery problems, for those of you worried about that! Using NiMH batteries.
But today I started trying the camera with my existing lenses. After all, the main reason to buy a Pentax DSLR was to be able to use my existing lenses! I tried the Pentax-A 50/1.4 first. No problems. Then the Voigtländer 180/4. It felt a bit scratchy to mount, but worked well. Then I tried to install my Tokina 28/2.8. There was a problem with this: It seemed to lock in position, after rotating it about a little less than halfway to the correct position. I tried to remove it again, but it was pretty much locked in place. It would move very easily and loosely by only one degree or so, but seemed to hit hard edges there, both forward and back.
I gently forced it back to remove it. It didn't take much force at all, just a little more than normal to remove a tight-seating lens. But after that, the K-x is DEAD! It won't power up!!!
I can't see any damage at the K-x lens mount, contacts, aperture coupler, or anything, and anyway the force I had to apply is not like it should be able to cause any damage. So I don't know if the misfitting lens is at all involved in the problem, or if it was just pure chance that the camera died at that moment.
To avoid any questions in that line: I did remove and reinstall the batteries, I checked the batteries to make sure they are still charged, I also swapped in a fresh set of batteries. No change. The K-x is dead.
What can I do? Any suggestions?
The issue is that returning it to the store is easier said than done. I live in Chile, and I had to order the camera from overseas. I ordered it from B&H in New York. Returning it implies expensive shipping each way, plus doing huge paperwork to recover the over 200 dollars I had to pay in Chilean tax, or else loose that money and pay the tax again when the repaired or replacement camera arrives.
I have done repairs on cameras, and I'm an electronic engineer. So if this is anything I can fix myself, I would prefer that route. But of course, opening a brand new camera and trying to detect a problem without any technical information on it, is pretty hopeless and foolhardy, as that would certainly void any warranty!
Would there be any warranty at all, or will Pentax or B&H argue that since I tried a non-Pentax lens on it (even if it is of course a Pentax-A type mount!), any warranty is void?
WHAT CAN I DO???
Manfred
