Originally posted by Tex Eric: I have seriously thought about Noise Ninja, for the price it certainly seems like a good idea. It might help for my more higher PP shots. But I feel like the camera could do a better job.
I think that if you play a little with the noise reduction settings in what ever editor you are using, you will quickly learn what you need with out noise ninja. I have it and while it works, I find it is too aggressive at times, it is better to really learn how your software package works. just my opinion
Quote:
Lowell; I need to stick with at least 500 for a shutter speed. I still have blurred parts of my image, enough to give a feel of movement but without ruining the shot. Going to the 100-300 range just makes the hands, feet and balls too blurred for my taste. It is even more of a problem when I shoot baseball as the bats and balls really move fast!
this prompted me to go back and look at some Taekwon-Do shots I took, I could almost freeze a persons foot going through a board at 1/180th, so I am a little confused at 1/500 for volley ball. I will go back and see if I have some basket ball shots to look at the movement there as well. Again it is just an observation
Quote:
About WB... sheesh... the lights are from Mars or somewhere..
are you sure they are in our solar system, I have never seen any gym lights even close
Quote: and each gym/field is different.
agreed
Quote: I usually just do a WB on the shots that I PP, by selecting a part of the white shirt or something else. I have better luck with that. And at times I get gyms that have yellowish walls that are just plain ugly with a regular WB, so I try to tweak the color to make it look less like puke and more like a gym wall.
if the K20 is like K10 and K7, the WB is easy to adjust. just take a shot, and while it is in the buffer, select Fn - WB and the image will appear, you can then play with the settings and see the image change interactively, pick what is more pleasing for that gym and then go with it. It will be a whole lot closer than what you have now.
Quote:
I have never set the WB using a white card. I probably should try that. There are a couple of WB cards or filter caps that people swear by...
neither have I, I use the procedure noted above
Quote:
As far as the settings... heck I don't know. As I said, I set it up based on some sports shooter, then reset them based on another article I read.. so it is probably way off. I really don't know how to set it properly.
just take some sample shots before hand with different contrst and sharpness, chech these yourself, and you may get a better balance or more to your taste, if that is the issue. Note that in many camera reviews they comment on JPEG image quality as it is set from the factory and each camera company (read this software geek inside said company) has a different idea as to a good image. Perhaps not the same as yours
Quote:
Overall I have been happy with my lens. When I shoot football in daylight I get great shots. There is nothing wrong with the quality of the Tammy lens.
I would agree, I have a sigma F2.8 and if I have an issue with Image Quality it is because of what is behind the camera not in front of it.
