Originally posted by audiobomber I own a K20D and I've only handled a K-x in a store. I believe the K20D is by far the better choice as a pro camera.
Wireless flash
14.6mp gives more detail and finer grain structure
Better balance with larger lenses
Li-ion battery for extended shooting
Available battery grip / vertical grip
Famous for ergonomics (all the buttons are in the right spots)
Pentaprism viewfinder
Top LCD panel
Weather seals and more solid construction.
TAv, User and Sensitivity modes, no annoying scene modes to cycle through
Switch for metering mode (eval, spot, CW)
Switch for changing focal points, with visual indication of focal point
Flash sync socket
AF fine tuning (adjust lenses individually for front or back focus)
thought I would do a little counter point (many agreements as well though!)
K-x has wireless flash sync (that or there is a ghost in my house firing the flash when I press the shutter!).
the detail from either cameras is kind of like splitting hairs, sensors have come very far!
I actually like the balance on the K-x as well (have the k20 w/grip too) - even with the 50-135 the K-x is kind of more attached to the lens than vice-versa - my left hand partially supports both body and lens, and is quite comfortable - I think this is pretty much a wash/personal preference.
Haven't had any problems with battery life (and any problems have been addressed via the firmware update).
I do like the ergonomics of a grip, but don't miss it when I'm handling a smaller camera like the Kx.
The remaining ergonomics all come down to user knowledge and preference - I absolutely love the handling of the K20 as well - buttons are logically placed, viewfinder is nice and bright, top LCD is a plus (but not really missed when using the Kx either), TAv, user modes, AF adjustments are all apart of a camera that originally retailed at $1299 - if you know your way around a camera, understand its functions and how they relate to getting the right shot, these are all big pluses.
While the Kx doesn't have all of the ergonomic accessibility, it does get enough of it right, and in the right spot, that I don't feel like I am being held back. Once all of the long term settings are adjusted to your liking, I have just been using P mode, with the rear dial set to adjust aperture. ISO set to auto upto 2500 - if I want to go higher than that, Sv is the next setting on the mode dial, and I have that tuned to start at ISO4000. EV compensation is achieved quickly via a button next to the shutter and a quick turn of the rear dial. The AF on this camera is noticeably quicker, and better in low light, and also a higher FPS if you need that sort of thing. You also have access to pretty much all the higher functions (WB, ISO, Shooting modes, AF modes, metering, etc) via a single button press, or the rear lcd.
Personally, the only thing keeping my k20d on the shelf at the moment is weather sealing. I might have picked it up once since receiving the K-x. That is my not-so-brief assessment!
