11-22-2006, 01:12 PM   #1
arbutusq's Avatar
SR and pixel level sharpness
When you take pictures with SR active are the results as sharp at pixel level as you would get from using a tripod? or is there a slight loss of acuity from the movement of the sensor?
11-22-2006, 02:08 PM   #2
Yesterday I made some test shots at home from tripod. By accident I forgot to switch off shake reduction, so I repeat shot with SR OFF. Shots were taken at RAW on K100D with Carl Zeiss Flektogon 20mm.
I noticed no visible difference.
11-22-2006, 02:20 PM   #3
Just forgot to insert images:
SR-off
SR-ON
Exposure: F8, 1/8sec, ISO200
11-22-2006, 03:34 PM   #4
arbutusq's Avatar
Thanks, that's encouraging I guess I should have been clearer with my question though. Does SR without tripod give as sharp results as no SR taken from a tripod.
11-22-2006, 09:28 PM   #5
jeffkrol's Avatar
Think it's a matter of odds. Sometimes yes, sometimes no. I don't think of SR as a substitute for a tripod, MLU and remote release.
11-24-2006, 04:08 AM   #6
pathy's Avatar
Well, if SR delivers more often than not, I may not have to lug my tripod on all those trekking trips.
Or perhaps, it's still a good idea to carry the tripod - because I don't own some of the most sharpest lenses. Tripod & MLU might be the best bet.
11-24-2006, 04:46 AM   #7
peted's Avatar
I guess we should always be mindful that our shutter speeds are up there so we don't really need SR.
11-24-2006, 09:31 AM   #8
arbutusq's Avatar
QuoteOriginally posted by pathy Quote
My thoughts exactly. A heavy tripod is a royal pain in the butt on a multi day backpacking trip. The K100 is small, light and damn cool.
11-29-2006, 02:26 PM   #9
Michael Barker's Avatar
The main thing about the tripod for me is that sometimes you need not 2-3 stops which SR can give you, you really want 4 or 5 stops so that you can have maximum depth of field. There's also things like HDR merging and stuff, but this is the main thing for me.
11-29-2006, 02:29 PM   #10
arbutusq's Avatar
QuoteOriginally posted by Michael Barkowski Quote
Too true, but one of the things I like about SR is that I can use a higher fstop and still hand hold without a tripod. I'm hoping that SR combined with some of the steadying tricks I learned a long time ago can get me more stops without a tripod.
camera, dslr, level, photography, pixel, sr, sr and pixel
k-7 sharpness / fine sharpness / fine sharpness 2 mattdm Pentax DSLR Discussion 10 12-12-2010 08:10 AM
Sharpness VS Fine-Sharpness in k20d wasim_altaf Pentax DSLR Discussion 8 10-12-2009 11:41 AM
Sharpness vs Fine Sharpness on K20D morfic Pentax DSLR Discussion 2 11-02-2008 10:13 AM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
Differing level of sharpness in the same image matiki Photographic Technique 12 07-03-2008 02:31 PM
All times are GMT -7. The time now is 11:02 AM. | See also: NikonForums.com, part of our network of photo forums!
