12-18-2009, 12:06 AM   #16
Steve Beswick's Avatar
QuoteOriginally posted by LeDave Quote
Faster AF, better low-light AF, better metering system, cool green top LCD, 3.0 inch LCD, LCD has 920,000 pixels, CA and distortion correction, electronic leveling, more frames per second, and HD video recording.
Make that 10:0
You are off by one, unless the K20 lacks the green backlight the K10 has.
12-18-2009, 01:33 AM   #17
That's really nice! Can you use it for indoor portraiture so that external details which are visible through the windows won't be blown out?
My K20D just bit the bucket and the local repair center will not be able to repair it in time. I have no choice but to order another body to shoot a wedding next Saturday. My backup (an istDS) is just too slow to use as my primary camera, so I have to get a KX or the K7. If the in camera HDR can work for formal portraits, then I will get the K7. Heck, I'll probably get the K7 anyway.
12-18-2009, 02:14 AM   #18
*isteve's Avatar
Chris, firstly welcome back to the fold and, secondly, thanks for showing everyone how pros really do benefit from in-camera processing (its called throughput boys and girls). The HDR stuff is not amazing, but its good enough for real estate use, a lot quicker than doing it manually, and a lot cheaper than rigging up $2000 worth of lighting.
As for the AF, well at least its got a focus light and it seems a lot more accurate - especially in tungsten light. I don't shoot sport so to me its a non-issue, but it goes to show you cant have it all in one camera. For travel, street and portrait work, its just dandy.
12-18-2009, 05:52 AM   #19
QuoteOriginally posted by HawaiianOnline Quote
No, it won't work for that application as with "old fashioned" HDR it takes 3 exposures and combines them. Any moving element (like a person) won't likely be rendered properly due to movement between the 3 frames... If you want to show window details you'll have to so it the old fashioned way, by artificially lighting your subject indoors while simultaneously exposing for the window details.
If I were a Pentax wedding photographer (which I am not, I shoot my pro weddings with Canon 1 series cameras), I would probably use the K-x for its high ISO performance over the K-7.
Hope this helps,
Chris Miller
Imagine Imagery, Photography by Chris Miller
12-18-2009, 07:40 AM   #20
Banned
K-7 & 10-24mm Tamron @10mm with and without HDR mode:
12-18-2009, 07:47 AM   #21
QuoteOriginally posted by chrisdm Quote
I'm not sure how to or why I would want to post a blown crop at 100% (I am not a "pixel peeper"), but I will tell you that I regularly produce and publish HDRs that I generate manually from my Canon 5D2 and Photomatix software, and I shoot this type of work at low ISOs, expose properly and process cleanly so there is no noise. And fortunately the same can be said of the low ISO HDRs from the K-7, they are clean, assuming I get the exposure right.
Chris Miller
How? You just crop and post. Why? Because i'd like to see if it's horribly noisy which i cannot tell from an image that has been downsized so much.
It does appear that i had this the wrong way around though, I thought the camera was using one image then lifting the shadows but it's actually similar to Photomatix (which i use) in that it uses multiple images.
12-18-2009, 08:56 AM   #22
ivoire's Avatar
I've been using the hdr feature for real estate pics also. It cut my post processing times by 2/3. In the link below, 80% of the interior images were done using the hdr feature.
http://3difocus.com/slideshows/312-E-Ninth/
12-18-2009, 09:33 AM   #23
wll
QuoteOriginally posted by ivoire Quote
Very, very nice and a very usefull way to use HDR in the real world of business ..... nice job !
wll
12-18-2009, 09:42 AM   #24
jacksonpritt's Avatar
Impressive photos!
I've been thinking about branching out into real estate photography lately (nothing this high-end, mostly condos & apartments) and this seems like it would come in really handy.
This is the kind of HDR that's actually useful, instead of that overdone crap everyone is always posting on Flickr.
12-18-2009, 11:04 AM   #25
I checked out your pics and I liked the one with the child's room. There is a shadow from a desk chair that is very distinct and looks slightly out of place in such a well-lit room. Interesting.
12-18-2009, 11:12 AM   #26
great exampels that shows the k-7s small dynamik range
12-18-2009, 11:20 AM   #27
QuoteOriginally posted by eigelb Quote
Is this supposed to be an insult?
12-18-2009, 11:46 AM   #28
ivoire's Avatar
QuoteOriginally posted by dragonfly Quote
I believe the shadow comes from the wall light above the bow of the boat. The rooms lighting is mostly a product of using the metz af1 flash while shooting with the HDR 1 setting. Color, dynamic range and depth are best achieved with a lighting setup, so there is always a trade-off when using HDR and a camera mounted flash. The shadow is less obvious in the non flash raw pics I took as backup to HDR, but the room is much darker.
12-18-2009, 12:40 PM   #29
QuoteOriginally posted by Daemos Quote
Can I insult a camera?
No its only an observation....
12-18-2009, 05:13 PM   #30
I think it was sarcasm. With its HDR feature the K-7 beats the nearest competitor in terms of dynamic range by at least 6 stops. Dpreview measured 17EV of dynamic range!! That would be a world record for a DSLR if Guiness tallies such things...
camera, chris, dslr, hdr, in-camera, job, lot, miller, night, pentax, photography
Architecture Wonder Works Fl_Gulfer Post Your Photos! 2 09-05-2010 01:58 PM
HDR labs -Review HDR in K-7 redpigeons Pentax News and Rumors 60 04-27-2010 09:43 PM
HDR Software - Dynamic-Photo HDR mithrandir Digital Processing, Software, and Printing 3 03-03-2009 08:46 PM
28 M works well? Fonnyboy Pentax SLR Lens Discussion 8 04-07-2008 12:49 AM
2 Shot HDR Pano, works quite well. Avantphoto Post Your Photos! 9 08-21-2007 01:52 PM
All times are GMT -7. The time now is 07:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
