Originally posted by slow2focus I am fairly new to slr and k-x. I currently have a 35mm and 28mm super-tak to get my feet wet in manual focus. I like the 35mm FOV for around the house a bit better than the 28mm. I find I don't have to get as close and spook the subjects. I like it enough that I may search a A version so I can at least have some help on metering. In truth, 98% of my shot with these 2 lenses are blurry.
Keep practicing - MF definitely is a learnable skill. It's all about not just looking at your subject and deciding yes/no, but watching the focus zone as you turn the ring, and stopping when it is one your subject. Turn the ring to put it clearly behind your subject, turn again to put it front, then go for the middle.
Also, you *do* have help with metering even on non-A lenses K-mount lenses. Simply hit the Green button to get the camera to meter and choose a shutter speed for you, or do a DOF preview and see a "live" meter reading. With M42 lenses (which yours might be), it's even easier - you can simply use Av mode, can you not? Although you'd want to be sure to *focus* with the lens wide open so your viewfinder doesn't dim.
Quote: lack of red light really kills me.
The red light is of no real use with manual focus lenses. All it will do is light up in the center when you are getting close, which is something you can see for yourself. You still need to wait for the green hexagon to tell you when the camera thinks focus has been achieved.
Quote: Half the time, I thought I saw the subject clear in the VF but the green light don't come on.
It can lag. And it only works on the center. I find it occasionally useful, but I'm still way better off trusting my eyes.
Quote: One theory I have is that the diopter thingy must not be set right. But, prior to the manuals, when my kit lens beeps, I see subject is clear. So, I think the diopter is right.
Test it anyhow.
Also consider a $40 O-ME53 viewfinder magnifier - I find it helps a bit.
