12-21-2009, 04:56 PM   #31
Pentaxor's Avatar
QuoteOriginally posted by pcarfan Quote
I wonder what is so special about the jpeg engine.
for those who want to have a quick print on a 5x8 or less dimension. and for those who are too lazy to do PP work.
12-22-2009, 09:55 AM   #32
Marc Sabatella's Avatar
You don't need JPEG to do a quick print, nor does shooting RAW require you to do PP.
12-22-2009, 10:51 AM   #33
Pentaxor's Avatar
Marc, some printers and photo kiosks don't recognize RAW and in the event that you only have the memory card with you, and not the camera. and RAW is more advisable in post-processing. not to mention that it also eats a lot of space which can really be a bother.
12-22-2009, 12:08 PM   #34
True. I'm not saying JPEG has no place - just responding to the specific misinformation in your previous post. Had you said, "quick print at a kiosk" (something I've never done in my life, but recognize that others do), I'd not have taken issue with that statement. But since all my small prints are done at home, that was what I assumed you were referring to as well. And prints at home - of any size, actually - do *not* require JPEG.
Not sure what you mean by saying "RAW is more advisable in post-processing" - sounds almost like you are making that as an argument for shooting JPEG, but of course it's obviously the reverse. If you know you'll not want to do PP, RAW has no advantage. If you're not sure, RAW has the advantage, assuming you are OK with the size penalty. Note the size penalty goes away practically the moment you begin PP, since JPEG normally requires you to save copies of the file (assuming you don't wish to overwrite your originals). If on the other hand you were claim that if you shoot RAW, it is advisable to do PP, that's just a myth. A 100% falsehood perpetuated over the years, that may have once had basis in truth a decade or so ago (back when the statement "digital photography will never catch on" would also have been seen as probably true), but hasn't bee true for a very long time.
Again, I'm not out to convert anyone - just to correct the misinformation that unfortunately is very commonly spread about shooting RAW. When people make up their minds on how to shoot, I want it to based on facts.
12-28-2009, 04:09 PM   #35
Why is it a myth that PP is advisable when shooting RAW ?
12-28-2009, 04:51 PM   #36
distudio's Avatar
QuoteOriginally posted by Jonson PL Quote
Because anyone can open up Picasa or any such program and print a RAW image as if it were a jpeg without any additional processing.
12-28-2009, 05:26 PM   #37
Pentaxor's Avatar
QuoteOriginally posted by distudio Quote
sadly, photo kiosks don't use Picasa yet.
12-28-2009, 06:55 PM   #38
Lowell Goudge's Avatar
I did something today I don't normally do, shoot RAW
Just out of curiosity to look at 3200 ISO performance on my K7
Note the shot below, resized to 20% and using 1 step noise removal in PSP X2
the shot is at 3200 ISO, 1/40th of a second with a 510mm lens at F13 (F8 on the 300mm F4 and a 1.7x AF TC) Hand held.
12-28-2009, 06:59 PM   #39
And vice versa - fast glass can't replace high ISO. Fast glass allows faster shutter speeds, but at the cost of DOF, and often sharpness, CA, vignetting, and other artifacts that tend to disappear as one stops down. So you have to make that choice, and sometimes one is more appropriate than the other. Plus, sufficiently fast glass is not available or indeed even feasible at many focal length (anyone ever seen a 300/1.2?)
And often, one needs *both* a large aperture and a high ISO to capture a given scene.
how true but F2.8 stopped down to F5.6 is faster than F5.6 stopped down to F11. Most low cost lenses are out performed by their faster counterparts at the same aperture, and all the ills that exist at the fast wide open apertures on good fast glass, exist to some extent on cheaper slower lenses. Perhaps my example is a little bit of an exaggeration but the concept applies.
12-28-2009, 08:34 PM   #40
Because it's something that lots of people believe, but is in fact not true.
12-29-2009, 09:01 AM   #41
jpzk's Avatar
Marc,
If you are saying that shooting RAW doesn't necessarily mean that you HAVE to do PP, I totally agree. Some of the pics I take in RAW are just great "as is" and warrant no further tweaking, except for saving a file in JPEG or TIFF (and that is not PP), which I normally do before I bring the photo files to my buddy down the street for printing.
JP
01-10-2010, 01:28 AM   #42
Ok, thanks. I thought when I had changed from JPEG to RAW shooting, I had to take the time to set sharpening and contrast.
So if the picture looks good as it, it is fine just to save as JPEG and be done with it ?
01-10-2010, 10:26 AM   #43
You might if you don't happen to like the default sharpening and contrast settings from the particular RAW converter you use, and it doesn't provide a way of altering those defaults. Many will at least look at the setting you made in camera and try to honor those, if you prefer higher than default sharpening and contrast; others will provide a way of customizing the defaults in the software itself. But with most RAw software, one way or another, it should be possible to get results you like just fine without needing PP
Yes - and that's assuming your RAW workflow requires saving to JPEG at all. Most modern applications don't require this, whether you do PP or not - you can work with your RAW files directly. But of course, generating a JPEG - perhaps a lower resolution version - is a necessary step for pictures you intend to post online or otherwise share with others. I generally do PP on just the images I feel "need" it (and this "need" isn't because they were shot RAW, but because of the images themselves), then I kick off a batch conversion of just the images I want to keep these lower resolution JPEG copies of.
camera, detail, dslr, iq, jpegs, k7, k7 noise, kx, levels, noise, photography, settings
Question Re: K-x a different kind of noise Katsura Pentax DSLR Discussion 5 12-05-2009 11:37 PM
Question about noise Lainey Pentax DSLR Discussion 16 05-27-2009 11:44 AM
Trying To Lay the D-Range Question to Rest Das Boot Troubleshooting and Beginner Help 5 12-25-2008 01:39 PM
Noise Reduction question k20d jbrowning Pentax DSLR Discussion 10 10-22-2008 04:18 PM
Another noise question Eddie Pentax DSLR Discussion 9 11-15-2007 10:47 AM
All times are GMT -7. The time now is 06:16 AM. | See also: NikonForums.com, part of our network of photo forums!
