12-21-2009, 11:03 PM   #1
yellow streaking
I started using an A 50mm 1.7 today and some pictures had a yellow band while most were fine. What can be the cause? Is the lens bad?
12-21-2009, 11:36 PM   #2
inferno10's Avatar
I'm betting this was shot under fluorescent lighting. Fluorescent lighting, unlike halogen or tungsten, flickers on/off at the mains frequency (usually 50 or 60Hz); technically, it operates at twice the mains frequency. Someone correct me if I'm wrong, but most Pentax DSLRs are synced at 60Hz. Therefore, if your mains power operates at 50Hz or just slightly off 60Hz, the fluorescent bulb will flickr slightly out of sync with the camera's shutter. As a result, you will get bars of discoloration when the out-of-sync lighting conditions changed while the sensor was capturing that part of the image.
Hope that makes sense.
- Jason
12-21-2009, 11:43 PM   #3
Wow! Yes it was fluorescent light. That was really informative...I was freaking out. Thanks!
12-21-2009, 11:44 PM   #4
I'd second that
Looks like fluorescent light. Try slower shutter speed, like 1/30s.
Fluorescent bulbs do not emit in the spectrum simultaneously - they oscillate through the spectrum, and with high enough shutter, you can catch the transition.
12-22-2009, 10:04 AM   #5
Wheatfield's Avatar
Check this series shot with my K20. Ignore the fact that the AF couldn't keep up, that wasn't the purpose.
A Picture
12-22-2009, 02:44 PM   #6
Lloydy's Avatar
A Picture
That's an amazing sequence, and a great reminder to set the colour balance.
12-22-2009, 04:57 PM   #7
Wheatfield's Avatar
QuoteOriginally posted by Lloydy Quote
White balance wouldn't have helped. That sequence was shot RAW. The colour was all over the place because I was catching the florescent lights out of phase.
12-22-2009, 08:10 PM   #8
I've noticed this before with my K-7 and K-x... a orange/yellow tint at the bottom or top edge of the frame. Nice to know there's an explanation.
12-23-2009, 03:13 PM   #9
Lloydy's Avatar
wouldn't the colour temp of the lights remain constant enough to not record the shift / flicker from the phase fluctuation if the camera was set for flourescent light?
12-24-2009, 06:54 AM   #10
Wheatfield's Avatar
no.
12-25-2009, 05:17 AM   #11
Very interesting! Another lesson learnt.
camera, dslr, photography
Macro Yellow On Yellow shooz Photo Critique 2 06-28-2010 11:12 AM
Night ISS streaking over Ohio aerodave Post Your Photos! 4 03-05-2010 08:12 PM
Landscape Yellow Ole Photo Critique 6 10-08-2009 07:53 PM
Yellow metalfab Post Your Photos! 1 04-07-2008 02:15 AM
Yellow kmccanta Post Your Photos! 0 03-11-2008 12:28 PM
All times are GMT -7. The time now is 05:52 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
