Originally posted by attack11 Theres no reason to bracket once you can compose the shot at set the camera properly. Sounds like you need to practice metering.
Wrong. Just plain wrong. There are a large number of reasons why bracketing is useful, and that is why the function is found on Pro Cameras as well.
As for what the reasons ARE, I know what MY reasons are, the OP knows HIS reasons. If you don't have any reasons then perhaps my advice would be, there's no reason to leave messages about bracketing advice if you don't use it.
bnorikane, I am interested in the answer to this, since I do just what you want to do on my K10D and K20D. I am pretty sure I saw this issue raised elsewhere and that the K7 actually has the same issue. I wish I could contribute to this, but I will follow the answers with interest.
EDIT: I did find something on dpreview with respect to the K7 that indicates that there is a work-around for the MLU issue for regular exposure bracketing - use live view, with the AF set to contrast-detect AF in the appropriate menu -- this will cause the mirror to remain locked up for the entire sequence. Since your Kx has Live View, perhaps this will work?
sure
