12-22-2009, 06:08 PM   #16
Igilligan
Guest
Amazon had the Kx + 18-55mm + 55-300 for $650
You will not find a much better deal than that for a while...
12-22-2009, 06:54 PM   #17
aleonx3's Avatar
QuoteOriginally posted by interested_observer Quote
I don't have a lot to add, other than on the lens attached to the Ricoh, if it is a Ricoh lens, do not use it on a Pentax body, as the lens has an extra pin that gets caught on the Pentax body's flange and the lens tends to get stuck on the body.
Contrary to everybody's fear about the dreaded pin get stuck in the Pentax DSLR body, I have both Ricoh Rikenon P 50mm f2 and f1.7 MF lens - there is a pin but it does not get stuck - almost flush with the base flange. I suspect that if you have a third party lens which has the dreadful pin for the Ricoh mount, that could be problematic. I have not seen one yet - you can check on Hinman's blog site. And then I also have the XR Rikenon 50mm f2. This one is really nice with metal housing and heavier than the later P version. My Ricoh MF lenses are sharp and contrasty, but they all use 52mm filter size instead of 49mm. These MF lens are fun and easy to use with the green button on my K10D.
12-23-2009, 01:37 AM   #18
QuoteOriginally posted by Dom Quote
Correct me if I'm wrong but does not the K-x use AA batteries?
haha you pick out one common feature, and one as trivial as battery type, and suggest a direct comparison based on that? Yes I know he said he likes lithium, but there are many more similarities between the K-x and his canon which make it a much more suitable replacement. And really, eneloops are brilliant. I brought 3 packs with me to Africa this trip, 3 weeks in and still on my first set
It's like saying he should buy the K20d as it only comes in black, just like the Canon!
12-23-2009, 03:49 AM   #19
Dom
Guest
QuoteOriginally posted by 68deluxe Quote
Well you've told me a lot about your self with your comments so far.
135mm, camera, canon, dslr, film, gear, lens, pentax, photography, trade, xs
Struggling with the switch from canon ps to pentax kx junerainbow Troubleshooting and Beginner Help 7 10-08-2010 11:07 AM
Pentax Electronic Cable Switch v/s Pentax Infrared Remote Control F brosen Pentax DSLR Discussion 9 10-26-2009 05:08 AM
For Sale - Sold: 8GB Sandisk Extreme III 30MB/s 200x SDHC, Pentax SF-10, Pentax Switch F jhaji Sold Items 9 09-15-2009 10:42 PM
Why one should switch from Canon to Pentax? sagar Photographic Technique 8 05-12-2009 07:00 AM
anyone switch from canon to pentax rwa Pentax DSLR Discussion 12 05-04-2008 07:13 AM
All times are GMT -7. The time now is 10:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
