12-22-2009, 02:00 PM   #1
k-x timelapse
Hello
Is it possible to do timelapse with the k-x?
i know there is no option in-body like the k-7..... but is there a specific remote to use with the k-x to do timelapse? any help would be much appreciated!!!
12-22-2009, 02:51 PM   #2
Welcome to the Forums! - Normally, I would refer you to a device such as
Opteka Timer Remote Control for Digital SLR Cameras
but that is for a wired interface, and the KX body does not support that, only the IR. I have never really come across an intervalometer that is IR based. I understand that Pentax wants to tier their various camera bodies, however in this case leaving off the wired interface I think is somewhat self defeating. The wired interface was on the K100 and K200 and I also think the KM/2000. Wired and IR are also used on the K10, K20 and K7.
Another way is to potentially use the USB interface, however I understand that the Pentax Remote Assistant does not work with the KX.
https://www.pentaxforums.com/forums/pentax-news-rumors/73954-k-x-remote-software.html
Back to the IR interface, I did a search - it appears others have considered it, but I really did not find anything....
IR intervalometer slr - Google Search
infrared intervalometer slr - Google Search
http://www.google.com/search?hl=en&client=firefox-a&rls=org.mozilla%3Aen-US%...&aq=f&oq=&aqi=
That was the long answer - the short answer seems to be no.
12-26-2009, 09:34 AM   #3
It looks like I was wrong. I just ran across this device and it does IR along with wired. The IR feature is oriented towards the older *ist Pentax line, however Pentax's own IR controller works across all models (the *ist and the K model cameras), so I would think that this should also work, however I would either call or email them a question.
Pclix LT Introduction and click on compatible camera models
Pclix LT Custom Cables Look at the first table.
It looks like they have cables that run from the unit to someplace near the IR sensor on the camera, but that is only a guess.
Its a tad expensive, however it appears that this may be a solution for time lapsed photography with the KX.
12-28-2009, 02:06 AM   #4
thank v much for your answer...
i ran across this pclix site a little while ago, but i didnt pay attention to it.
maybe you are right but it felt a bit strange to be able to do timelapse with an IR remote at the time i saw the site (my guess).
Anyway thank you again for you answer. i ll send them an email to clarify this matter!
Happy new year, all the best!!
12-28-2009, 03:24 AM   #5
tux
surely time-lapse would be trivial to add to a new firmware ? I cant think of any hardware limitations, just a missing software feature.
12-28-2009, 05:46 AM   #6
yeah, it is just a software limitation and probably deliberate to give people an extra reason to buy a k7.
12-28-2009, 06:30 AM   #7
netrex's Avatar
QuoteOriginally posted by WerTicus Quote
The interval function in the K-7 isn't much of a reason. It only takes 99 images AFAIK.
A remote control or wire release is the way to go.
12-28-2009, 06:35 AM   #8
falconeye's Avatar
QuoteOriginally posted by le0n Quote
Hello
The smartest solution will be a freeware application, assuming you still have an old PDA sitting around -- now that we all moved to smartphones
Remote Control For Pentax Windows Mobile phone Pocket PC freeware software mobile download
There was a thread here in PF but cannot find it ...
12-28-2009, 08:27 AM   #9
Pclix and IR support for Pentax KX
Morning, I sent an email to PCLIX and they have responded......
___________________________
Hello,
First off, thanks very much for your message and also for your interest in my product the Pclix LT. In answer to your questions I would say the following. Your camera the Pentax KX can only be triggered using infrared light which the Pclix is able to do. We sell our C-100 optical infrared cable ($22 USD) which is compatible with the Pentax KX and all other cameras which are also triggered using infrared light. Basically the cable at one end plugs into the Pclix while the other gets taped directly overtop of the infrared receiver on your camera. Not using a bad-aid as you suggest but a few small pieces of black electrical tape. The advantage to the black tape is that it is fully opaque and leaves no visible trace once removed. I have hundreds of clients using this exact setup all over the world with great success. If you would like to speak on the phone regarding the use of the Pclix with your Pentax KX I would be more than happy to do so. I'll add this camera model to the website in the next few days, thanks for pointing this model out. If you have any other questions email anytime or call me in Toronto, Canada (EST) at 1-416-948-3081. Thanks again. Hope all is well
ciao
paul cormack
Timelapse Photography using the Pclix LT and the digital camera you already own.
please visit our user gallery
Pclix LT Time-lapse User Gallery
visit Pclix on Facebook
On 2009-12-26, at 12:33 PM, wrote:
> Good Morning,
> Just a question and a possible suggestion. Pentax in their infinite wisdom has chosen to only have IR support on their KX model - for remote control. I see that Pclix supports IR for the Pentax *ist line. Pentax's IR unit is supported across its entire camera body line (*ist through the K bodies). So does the Pclix support the K line, i.e., the KX?
> If so, could you update your website with some information to that effect, and include some details on how the unit works in the IR mode? In particular the IR connection to the camera. I see you have IR cables, but how do they connect with the camera - a band-aid holding the cable over the IR sensor or ...??
> Thanks,
02-28-2010, 10:29 AM   #10
PClix for Pentax Kx timelapse.
Hello
I bought the PClix to use with my Kx for astrophotography. It basically works fine. It can be used wireless, like a TV remote, but for long term astrophotography, it's useful to use their optical fiber connector so that the IR signal is always right at the sensor. I am not thrilled with the connection ("use a piece of electrical tape to hold the optical fiber over the sensor.") This is fine for a while, at least in dry conditions, but if you get a lot of dew, the optical fiber has been known to come loose from the tape. I think I will try to fab a slip with Kydex.
In fairness to the people at PClix, I haven't given this feedback to them yet.
03-01-2010, 03:27 PM   #11
Do you want to do something like this? YouTube - Time Lapse ????????????????
I have no idea how this guy did it, and he hasn't asnwered any questions yet...
03-01-2010, 11:44 PM   #12
netrex's Avatar
QuoteOriginally posted by Ed Flanders Quote
Unless he did it manually, I don't see any other way of doing it than with a remote control, or wire release, that works with IR and can be set up to do it automatically.
As mentioned above, this works for the K-x: https://www.pclix.com/shopping/shopdisplayproducts.asp?search=yes&bc=no
03-07-2010, 06:43 AM   #13
The strangest thing is that the ORIGINAL K-x spec INCLUDED timelapse in the firmware! They even had it featured on the fancy flash website that was up before the body was released... Then they scrapped it for some reason!!
03-07-2010, 07:44 AM   #14
no help from Pentax
FYI I actually wrote Pentax about this, and got a reply from some upper-level manager who basically said the flash intro on the website that mentioned time lapse was in error, and that he'd pass along the suggestion. Which is code language for "don't expect this any time soon in a firmware update." I imagine they are reserving it for the next steps up the Pentax line.
03-07-2010, 03:24 PM   #15
Internetpilot's Avatar
This is my solution, too, except since my old PDA's were Palm rather than Windows, I can still use it on my smartphone (Palm Treo 755p), which I believe was the last Palm smartphone to have an IR port. The IR port distance isn't very good on the Treo, strangely it works from BEHIND the K-X (must be bouncing off of something). The software I'm using is called Novii Remote Deluxe, and it was/is not freeware, but it was very popular for Palm PDA owners so if you still have a Palm PDA you might have Novii. Back when customizable universal remotes used to cost $4,000 (not kidding or exaggerating) my Palm Tungsten|C and Novii did the same job with my extensive home entertainment system for $30.
I have the IR profile for Pentax cameras for Novii if anyone wants it.
camera, dslr, k-x, photography, timelapse
Timelapse Question Spideralex90 Video Recording and Processing 7 06-19-2010 01:38 AM
Timelapse HDR? YossarianKL Photographic Technique 15 03-07-2010 10:11 AM
Timelapse software kthung Video Recording and Processing 11 02-02-2010 09:05 PM
K20 timelapse bentax Pentax DSLR Discussion 11 09-02-2009 09:13 AM
K20 D Timelapse Features spence.nicholson Pentax DSLR Discussion 1 06-14-2008 01:50 PM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
