12-22-2009, 11:09 PM   #1
Need help with the K20D built-in flash
I have a K20D & AF540 flash, the combination works well. One day I tried to use wireless flash sync, I found the Built-in flash could no Discharge. Then I tried every costom & flash setting, the flash still no fire.
Is it broken?
12-22-2009, 11:50 PM   #2
PrimeObjectif's Avatar
Set the camera to wireless flash, then mount the 540 in wireless mode to the camera, so the built-in flash and your 540 will be on the same channel. You should be good to go after that.
12-23-2009, 09:27 AM   #3
QuoteOriginally posted by PrimeObjectif Quote
I know how to set wireless sync with 540. The problem is the built-in flash can not fire in any setting. I think my K20D is broken.
Anyway, thanks a lot for reply.
12-23-2009, 01:06 PM   #4
Ash
Community Manager
Ash's Avatar
Does the popup flash work in normal shooting (when not in wireless mode)?
built-in, camera, dslr, flash, k20d, photography
K7 built-in flash in M sinus007 Pentax DSLR Discussion 17 08-18-2010 08:22 AM
In what situation can you use the external flash that the built in flash couldnt? rustynail925 Flashes, Lighting, and Studio 25 01-13-2010 01:26 PM
flash guide updated for k-7 built-in flash mattdm Pentax News and Rumors 4 05-26-2009 06:02 PM
K20D Built-in Flash ... questions jpzk Pentax DSLR Discussion 1 02-18-2009 09:11 PM
wireless flash using built in flash k200d dtra Flashes, Lighting, and Studio 3 04-04-2008 12:34 AM
All times are GMT -7. The time now is 03:58 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
