You know how when you flick the switch from MF to AF, the screw-drive pops out, while when you flick the switch from AF to MF, the screw pops in?
Wouldn't it be awesome if Pentax somehow designed the body in a way so that when you press the shutter half-way or the AF button, that the screw would pop out to AF. And when you lay your fingers off of it, the screw would pop in again? This would allow quick-shift in all lenses, especially ones from Sigma and Tamron which doesn't boast such a feature.
EDIT: Ah, epic fail. I don't know what I was thinking when I wrote this, but must be because it's 6am and I haven't slept yet. Obviously you won't be able to quick-shift after you release your fingers off it because it would have to re-AF when you press it again.
Well if there was a way to somehow program another button such as the dedicated AF button to do it. While your camera auto-focuses when your finger is half-way down on the shutter button, you can somehow press the dedicated AF button while still holding the shutter half-way down, thus allowing the screw-drive to pop-in for quick-shifting.
