12-24-2009, 07:41 PM   #1
ronin67's Avatar
Updating Firmware on K-7.
Alright, I downloaded the latest firmware update on a empty SD card. One thing I did notice is that the windows option didn't have Windows 7. Will this be an issue? Also, now that I have the latest version on my SD card, how do I install it on my K-7? I went thru the different menus in the camera, but couldn't find which one to push, to download the latest version. Can anyone help me out with this. Yes, I know it is probley easy, but I'm still learning the K-7 menu (use to using my Canon 50D and Olympus E-300 menus). Any help would be deeply appreciated!
Take Care and May God Bless!
Ed
12-24-2009, 08:26 PM   #2
Wheatfield's Avatar
Win 7 shouldn't matter. If the files extract, then it works.
If it doesn't, get someone to send you the extracted files.
There should have been a help file associated with the .bin file that was packed in the self extractor.
Please read it.
In a nutshell, you put the .bin file onto the root directory of a clean SD card. Put said card into the slot, close the door, and turn the camera on while pressing the menu button. You will be prompted by the camera from there.
Make sure you have a new battery in the camera.
I will not be held liable if you follow these instructions and things go sideways.
12-24-2009, 09:00 PM   #3
Hi Ed. If I remember correctly....insert SD card with firmware package. Then, turn the camera on while holding down the menu button. The camera will then prompt you to complete the upgrade.
Also, I'd advise you to check the install instructions on the pentax imaging usa website under support, firmware downloads and install. They should be the same for any firmware install.
12-24-2009, 10:19 PM   #4
ronin67's Avatar
Thanks for all the help guys. I got thru it. That put file in root directory was stopping me. I saved the update in the folder already established by the camera on the SD card. I erased the folder and installed same on the wiped clean SD card and it worked like a charm. What did this lastest update actually improve? I read it helped with something with the battery grip (which I have on my K-7/Pentax grip not aftermarket version).
Take Care and may God Bless you all during this Christmas Season.
Ed
camera, card, dslr, firmware, help, k-7, photography, sd, version, windows
Need help updating firmware in K10D, please Petdoc2b Troubleshooting and Beginner Help 5 04-26-2009 10:12 PM
Firmware Updating to 1.30 Jesus Pentax DSLR Discussion 7 05-24-2008 07:01 PM
updating firmware MikeD Photographic Technique 4 03-23-2008 05:24 PM
updating firmware CeeBee Pentax DSLR Discussion 3 12-09-2007 04:53 PM
All times are GMT -7. The time now is 06:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
